Need a switched fuse in the engine bay!
North Richland Hills, TX, USA
I'm looking for help finding a switched fuse inside the engine bay.
Fuse number 128 (15A) along with several others I've found have no power regardless of engine running. So I don't know what's up with that. I found this link with description of all fuses(Same info as in the manual). It shows #128 is a spare.
408hatch
Houston
The ones that say spare should powered. I used #82 (switched 20a) for my fuel-it ethanol sender. But definitely test first..
J
.. View attachment 9624
In your photo, it appears you are using #54, for the heated steering wheel. That should also be switched so you shouldn't have any issue. #82 is the yellow fuse, bottom left of your photo just below the 10A fuse.
I think I am going to tap into the rear wiper motor fuse(switched, tested). For my purpose, it will be relayed anyway, so should be minimal draw.
408hatch
Houston
Lol! You are correct, guess I don't use the wheel warmer much as I left the fuse out and haven't even noticed
N. Florida
Fuse 127 is the amp. It would be switched.
