Mono Amp Settings
If I'm using a DSP to control the output to a mono amp with Subsonic, LPF, Bass EQ and Gain, should all the settings be at minimum levels?
A sealed enclosure doesn’t use a subsonic filter at all.
LPF should be around 80
No EQ
Gain is used to level match the sources output. There’s no set level it should be at.
No EQ
So, Subsonic at zero, LPF at 80 (DSP is at 63 Hz) and EQ at zero? As for the gain, I’ve level matched the DSP/Amp gain for that channel, do I level match the mono amp to the DSP/Amp output or the main source?
