Length of wheel bolt
Seangi
Canada
FORD Explorer
Does anyone know how long the wheel bolts are?
I purchased 1inch wheel spacers however the existing wheel bolts prevent the wheel rim from mounting flush with the spacer. Perhaps a different way to ask this question is: What is the smallest width wheel spacer that can be installed on a 2023 Explorer?
If you want to run a 1” spacer either trim 1/4” off of your studs or replace all of them with the studs from an S550. If none of that sounds appealing run 1.25” spacers.
1” is the right fit though if you’re trying to get the oem wheels flush.
