JXB bushing insert
#81
Even though the deceleration whine isn't as loud as it was (for whatever reason), I still plan to remove the JXB inserts (on my 4 bolt) next chance I get. I don't notice any benefits and there are some unanswered questions in my mind. Like what does stiffening the rear do to the front of the diff? What does the significant loss of threads into the diff cover for the bolts do for the reliability--especially the drivers' side insert which sticks out a lot further? Too often, we enthusiasts mod with good intentions but ending up shooting ourselves in the foot.
#82
Just a pic showing thread markings. The upgraded bolt on the left was removed from passenger side mount with JXB insert. The other two are OE bolts from passenger side and driver side respectively with no JXB inserts. As anticipated, the bolts with the JXB inserts do not thread into the diff cover as much. Whether this is a concern s anyone's guess.
Jessup, MD, USA
I know this part helps with launches. Is there a noticeable improvement when just daily driving? I recently did the subframe inserts and could feel an immediate improvement even just driving around.
#84
Subframe inserts are definitely good. I don't notice anything with the JXB inserts except the noise...and not just the whine--there definitely knocking sounds too. It's almost a relief to have these removed. If you think the insert is just filling in the voids of the bushing, think again. The end of the bolts are banging against the body of the inserts which bangs against the collar of the subframe.
I gained no additional noise with the JXB inserts (4-bolt, no diff brace). None at all. But I did notice more immediate response in the diff. I think they are a great idea for any Explorer.
20 Platinum
#86
So seems like its a hit or miss on them for the 2 bolt people, so best to just stick with the Whoosh Stronger bolts instead
But even then, wont the 12.4 bolts be more prone to breaking IF it bends as opposed to the stock 10.9? Wouldn't the 10.9 benefit more especially for the rears that move a lot?
#87
If you have the 2-bolt rear and the upgraded bolts will do nothing. The 2-bolts don’t have the bolt snapping problem, if you’re launching a lot the bushings are prone to failure, which the JXB units stop.
20 Platinum
#88
Do you have the JXB inserts installed? Just looking at options if they're even worth spending the money on.
Increased NVH, seems like more like an annoyance dealing with the clanking sound than the unknown longer bushing life.
I have the single bolt set-up in my 25' ST. I upgraded to the grade 12.9 replacement bolt, I added a AWR diff brace, the JXB insert and also Steeda rear subframe bushing supports. I have no NVH or ill effect from any of it. I did all of this because I tow at, or near, the maximum GVWR when I pull my tandem trailer loaded with ATV's and dirtbikes. I have no faith in Ford's stock single bolt set-up, especially when towing heavy loads.
The harder 12.9 bolt will resisit bending and breaking over a 10.9 . It's a no brainer to me to at the very least change out that bolt with the 12.9 upgrade.
DSGR
Wilmington, North Carolina
#90
Added the JXB diff insert and stiffer both yesterday. Easy install, hardest part was getting the bolt torqued with very little room/leverage. (And yes I know the insert text is upside down, didn’t notice until I looked at the pics :ROFLMAO::ROFLMAO: )
Which bolt are you using? Was it difficult to remove the bolt? I understand the Explorer should be on a lift or jack stands and then use a floor jack to slightly support/lift the differential. Since the jack is used in the jack slots, where is the best location for the jack stands? I just bought a 2026 ST, which is also my first Explorer. Thanks!
