Increasing Speed Limit Restriction For MyKey
I searched here and in the ForScan forums but didn't find anything specific on this topic. Can the 80 MPH speed limit restriction be raised? It's not that I want her to be able to go over 80 MPH but the warning messeges and chimes are annoying. You have to drive 70-75 to keep up with the general flow of traffic. I'd like to be able to set it to around 87-88 so the warnings don't start when she gets up to 70 MPH.
Unfortunately I believe the 80MPh max limit is hard-coded in the vehicle programming. Not configurable.
Here are the directions from the owners manual. You will need to go into the settings to see what parameters can be changed.
h
h
The max is 80 going through the MyKey settings. There must be a way to set the max speed, just not through MyKey.
