If you want the best....
You go to the best. DC Customs has been doing lights and supplying bulbs for me for over a decade. Look Dan up on FB if you’re in the market. 30BEF601-6D3D-42A0-89E6-2A4A7E9C383E.jpeg
Jshaffer3819
Kaiserslautern, Germany
You go to the best. DC Customs has been doing lights and supplying bulbs for me for over a decade. Look Dan up on FB if you’re in the market. View attachment 1206
Interesting. What’s the purpose of changing the lights? Brighter? Just curious.
Chattanooga, TN, USA
To make a $60,000 car actually have LED lighting like it should have in the first place. My loaner Escape, base model, had LED tag lights. I was a little pissed when I first noticed the back end was all incandescent
Jshaffer3819
Honestly, I didn’t even know. Which lights are you replacing on the vehicle and are they all plug and play? I will replace them as well.
I replaced the reverse, turn signal and plate lights.
Jshaffer3819
Nice. Everything up front LED?
Yes
Plug in play? Standard blink after install?
P&P yes. Killed hyper flash on the dash with Forscan...the actual blinker was normal speed.
Austin, TX, USA
What is Forscan is or how do you install it. Sorry not familiar.
Skunk Hollow
You will need an adaptor to plug into the OBDII port. I bought mine off amazon
Skunk Hollow
Jshaffer3819
Skunk Hollow
I have the one that plugs into my laptop. I like the direct, hard wire connection vs bluetooth. Plus who the hell wants to squint looking at a cell phone screen when trying to change binary values in a string of x's and o's. Too easy to screw up IMHO.
Skunk Hollow
Dark mode? Sounds interesting.
Dark mode is standard in all the PIU's from the assy plant in Chicago. The interior lights have to be turned on manually. When locking/unlocking, none of the exterior lights will blink. Also kills the puddle lamps on the civilian models.
GTP
Indy
#20
LED reverse light is a must for sure.
