Help With Full Screen Mod
I've searched for help on installing the full screen mod from FMods with no luck.
When I go to install the 4th file nothing happens. Would any one have what files and folders should be on that flash drive.
Thanks in advance for any help.
Michigan (Detroit Area)
Open the ZIP-file, go into folder "dist". Copy the files in this folder to your USB-root.
You don't need the other files and folders in this ZIP-file.
your root should look like this:
Folder "SyncMyMod "
File "DONTINDX.MSA"
Nothing more, nothing less.
Good luck!
Pat
For some reason, the F-Mods team responsible for the 4th USB put the USB contents in a separate folder in their zip file instead of just unpacking the zip file to USB. You have to find the folder and place contents on the the USB drive. See Pat's response above.
D
So I just copy these 2 files from the download to my flash drive?
Folder "SyncMyMod "
File "DONTINDX.MSA"
And ignore the other files?
no, everything in that folder must be copied over to the usb drive.
D
It does not have an autoinstall
file. I would think it should.
It's a after-jailbreak-patch. It gets picked up by the daemon you install from the second USB-stick, not the OEM autoinstall-feature. Hence the different folder-name SyncMyMod instead of SyncMyRide.
