Fuel octane?
New Hampshire
That is the most outrageous gap I've ever heard of.
I live in CA and never seen a gap like that. Thanks DeSantis!
I would, of course, forgive the use of 89 in such terrible conditions. (I imagine 91 is a big jump too)
Here in NH 87 is $3.15 93 is $4.25 it’s outrageous. That being said I run 93 unless my wife fills it.
0blitr8r
Murfreesboro, Tennessee
2021 Ford Explorer ST
Been scrolling through replies, been using 87e10, curious of the difference between 90e0 and 93e10 if anyone had tested
Canby, OR
They definately run better on 93.
Gurnee, IL
I run C16 in my ST. Crazy how much faster it goes...
DC Area
2020 Ford Explorer ST ... 2003 Lincoln Aviator
C16 is leaded so it doesn't like cats or oxygen sensors. It is also much more corrosive to your fuel system.
Gurnee, IL
I know. This was very sarcastic post
Charlotte
2024 Explorer ST
Yep, running less than quality "top tier" whatever from the big names and highest available octane in your area is doing dis-justice to the ST. It's a must if tuned to run what your tune specifies as well of course. I threw a few bottles of octane boost/improver in the back just in case I'm somewhere that I can only get 91 with my ZFG 93 tune. Even so I'd probably put it in Eco mode which was untouched by the tune and deal with the loss of performance for safety.
I believe the PCM would be able to make the necessary adjustments if you had to fill up and only 91 was available. I don't think the difference between 91 and 93 is significant enough to cause any real adverse affects.
Raleigh NC
Help! A lot of back and forth. NC has 87, 89, and 93 readily available. The 2025 ST recommends 91 to achieve the full 400 HP. Best I can tell, the HP/performance difference in any of this is somewhat negligible. I can experiment but is 93 worth it... or should I just put in 87 and go with it. I'm 47 and can have a heavy foot and love to drive, but I'm also 47 now and it is becoming less important, lol. Thanks!
Performance is likely one of the reasons you purchased an ST, meaning you didn't buy an economy car. Why would you handicap it's potential before you ever hit the road? If 91 isn't available, run the 93.
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
Performance is likely one of the reasons you purchased an ST, meaning you didn't buy an economy car. Why would you neuter it's potential before you ever hit the road. If 91 isn't available, run the 93.
@GearHead_1:
Amen, Brother! Unfortunately here in Nor Cal, there is no 93 octane. Watered down 91 is the best you get.
I get that, but the member I responded to, listed 93, 89 and 87 as his options. 91 is all Ford is asking for, it's the best we have available in my area, too. I believe that's the fuel they used to get their 400 HP rating.
