Forscan iOS
NJ
I see that Forscan is now available on iOS, has any one used it and if so which adapter do I need? The one linked from Forscan's site is the BT version and $120, which seems pricey for what it does.
I know there are some other cheaper adapters on Amazon but I wasn't sure if they would work with the IOS version.
Thanks,
-Russ
Just get the recommended OBDLink MX+. it works great and you can still use it with windows. Forscan Lite iOS is called "lite" for a reason....but it makes for a good companion for windows Forscan to conveniently check codes and run serviice procedures.
R
NJ
JohnE
Vancouver, WA, USA
So would the lite version not be able to disable things like the double honk & remove hyper flash when putting in LED turn signals?
That's all I really need it for so seems silly to spend $120 on the adapter just for that.
What about this one:
https://smile.amazon.com/OBDLink-EX-FORScan-OBD-Adapter/dp/B081VQVD3F/ref=sr_1_3?crid=3RS9PMEVQ4IUS&keywords=OBDLink+MX+&qid=1644779726&sprefix=obdlink+mx+,aps,573&sr=8-3
That’s the one you want right there. $50 bucks.
EX if you want to use it with Windows. It is the most capable. Diagnostics, configuration, complex service procedures, module updates.
MX+ for iOS. Diagnostics and simple service procedures only. MX+ with windows gets you diagnostics, configuration, and service procedures.
