For scan and factory audio - outputs
New Albany, In.
2025, Explorer ST
It seems like I have read, at least on the pre-2025, people could use forscan to modify the APIM and or ACM to remove the factory DSP settings, and make the output from the amp a traditional linear output (no roll off).
  1. I guess my question is, am I reading that right?
  2. Can you change a single output, say the factory sub outputs (remove the EQ, roll off, etc...) for just that output so I can use that for an aftermarket amp and sub? I have a 2025 so I am interested in that specifically
