Fluid Change Conundrum
California
23 ST with 11k mixed highway / hard back road driving on weekends. In for a window seal service and wanted to knock out some fluid changes while they had it. Asked for an oil change, trans fluid change, rear diff change, and ptu change. Starting to think I should be kicking myself for not asking to run the front diff change as well. Wanted to be cautious as it's also heading for a tune as soon as service is complete and trying to extend reliability for as long as possible. Probably a bit paranoid to change these now...but what's the community think. Bite the extra 299 cost and add the front diff if they haven't gotten to the fluids yet? Next planned drive train fluid change aimed for 40k.
Can’t hurt.
Woppenheimer
California
Well, when you put it like that.... ha. Time to reach out to the service advisor.
11K?
Why do you want to change all those fluids at 11K miles?
Woppenheimer
California
Kind of the sentiment the dealer had too. I've been...pretty rough on it...but not the to standards I see some pulling these things down strips etc. Peace of mind? Insurance? Paranoid? Love this thing just want it to last.
Oh didn’t read :) At 11k miles you don’t need to do any of those fluids. At 40k or so is where I’d recommend doing them.
Those fluids (other than oil change) are on my list to get done on my '23 at some point between 30-40K miles, along with brake fluid. I'll be DIY however. I'm at 24K so i have a little time.
Desert South West
What method do you plan on using when changing the Transmission fluid?
Only do a full pan drop, do not flush these transmissions.
Woppenheimer
California
Thanks y’all! Seems caution won this round and noted for my next drivetrain fluid refresh.
South Carolina
Anyone have a link for the pan gasket? Assuming you have to replace it if you drop it.
wifeys-ST
Nunya
Gasket should last lifetime of the trans, it is reusable
It’s definitely better to replace it though. Mine started leaking on my old 2020 when my dealer tried to reuse it.
wifeys-ST
Nunya
Dang, that’s too bad. I wonder if they didn’t torque it correctly. Rockauto didn’t have the gasket available and I didn’t want to wait for shipping from elsewhere. If it starts leaking i’ll be happy to do a second trans drain and fill anyways. Since it only exchanges about 5-6 qt of the 12 total. I bought a harbor freight in-lb torque wrench for the pan specifically since the plastic needs a pretty specific torque to be successful.
Charlotte
2024 Explorer ST
I believe its a good idea to do diffs, trans, and PTU fluids early. It's a known fact that there is a break in period for these things that produces wear byproducts. Same goes for the first engine oil change. I go the extra mile and use a good reputable fluid/lube like Amsoil for replacement which in many cases provide higher performance like increased resistance to oxidation and temperature related degradation versus the Ford fluids.
