First Brake Replacement
jimzim66
NJ
Good morning all,
First time Explorer ST (2021, Street Pack) owner here, and coming up on my first brake pad/rotor replacement.
Really can't complain, I got good mileage out of my OEM pads and rotors, so I plan to go with Motorcraft again. I am confused on the exact model numbers I need, as there's multiple for each component, none which flat out list my application.
Rotors:
L1MZ-1125-B (Front, w/ Performance Brakes, w/ High Series Brakes)
L1MZ-1125-C (Front, w/ Premium Turbo Brakes)
L1MZ-2C02-6A (Rear, w/ Performance Brakes, w/ High Series Brakes)
L1MZ-2C02-6C (Rear, w/ Premium Turbo Brakes)
Pads:
L1MZ-2001-F (Front, w/ Performance Brakes, w/ High Series Brakes)
L1MZ-2001-G (Front, w/ Premium Turbo Brakes)
L1MZ-2200-J (Rear, w/ Performance Brakes, w/ High Series Brakes)
Thoughts/opinions/and flat out help is appreciated!
Manuich1
West Palm Beach, FL, USA
I believe our size 363mm for the fronts. See if you can look it up by size.
I bought pads -F and -J but don't quote me because I haven't installed them yet. Waiting for them to wear out. I like the stock setup too--best set of stock brakes I've ever had! Will likely get stock rotors too but haven't decided. You might want to check out Rockauto--sometimes they have more description like "w/ red caliper". As Manuich1 mentioned, front rotors are 363mm. Rears are 350mm. Both of those are larger than stock STs.
