Explorer Compliance Recall Notice 25C42/NTHSA Recall 25V543
Nascarbilly
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
Thread Starter #21
My opinion is that many of the quality issues on the Explorer are more related to the Chicago plant and not necessarily corporate Ford. They used to be a tooling customer of my former business and I’ve been there countless times. Worst run assembly plant of any type that I have seen. During BLM riots they were intentionally trashing police cars on their way through.
Having said that, my 22 has had a few recalls but I have never experienced the problems and don’t want them touching mine. On second thought, I did replace the 1 bolt rear subframe with a 2 bolt but I got the part reasonably cheap and did it myself.
All brands have issues to some extent these days. Honda and Toyota seeming being the best overall.
@Cruising68 : Until I got interested in the ST's, I never knew their final assembly was done at the Chicago plant (however, I became very aware of the Flat Rock, MI Mustang location). I'd be curious to see which model year since 2020 was the most problem free for the ST's. My wife has a 2025 Highlander Platinum Hybrid; she is highly confident her car will outlast my 2025 ST. With the exception of our collector and speciality cars, she and I generally keep our everyday cars well into their 200,000 plus to 260,000 mile range before ever thinking about replacing them.
I always find it interesting that recalls occur and all to often no parts are available for the recall yet they keep on pushing out the brand new vehicles with the parts they cannot get to satisfy the recall. Their priority is not the post purchase consumer experiencing the problems. It's all about the new sales they're chasing while you sit and wait. IMO, if their aren't parts available for a recall that are being put in new vehicles going down the line, the line should be shut down until all recalled vehicle parts demand has been furnished. That will never happen but that is how it should be.
I agree 100%.
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #24
@Caster @Cruising68
5 Nov 2025:
To all those following this thread, in full disclosure, my Wife's Toyota Highlander just fell victim to the dreaded "RECALL" notification today. Yes, her notification was for the rear view camera issue which came into her Toyota on-line notification account. There is no idea when the fix will arrive at the Toyota Dealerships.
Nunya
The real issue is many companies like Toyota issue TSBs, which act as phantom recalls. Ford doesn't do that anymore. They just issue the recall. And it's frustrating that they look bad because they're doing the right thing.
From what I’ve observed (and I mentioned this already), there are many issues that ford puts out TSBs for that should be recalled. Can’t speak for other manufacturers. But front axle disconnect actuators having a 100% failure rate early in life, and AWD module grounding failures could even be argued for being eligible for a safety recall because they both disable countless safety measures like brake assist, collision avoidance, hill climb, etc etc. I have recorded evidence that the grounding problem causes complete brake failure when switching out of park after a cold start. and those are just two issues I personally experienced with my explorer in the last year. I know there are more out there. When I get a safety recall notice, i just make my appointment and am glad it’s being acknowledged and mitigated. But there should be more recalls issued that ford just slaps a TSB on.
ChasVS
Tampa, Florida
Today, I received my first recall notice for my Explorer ST. This recall covers the "electronic components of the printed circuit board of the Body Control Module C (BCMC) that MAY have been improperly soldered. As a result, when a trailer is connected to the vehicle and the vehicle's trailer tow electrical connector is utilized, the trailer's taillamps may not illuminate as intended". Ford's letter went on to say "Inoperative trailer tail lamps reduce visibility to other drivers, increasing the risk for a crash."
However, please sit down for this, your vehicle may also experience the following operability problems with:
__inoperative power window/mirror switches
__vehicle's air conditioning system may blow warm air
__operability issues with DC/AC inverter
__glove box light
__vanity lights or dome lamps
__alarm portion of the horn
__rear defroster
__USB chargers
__and/or 12 volt points.
Thank God the car is still considered to be drivable according to Ford!! The parts for the fix are not out yet but is expected before the end of the year (2025).
Would you rather they not inform you of the issue until parts are available? Just sayin. They didn’t make the error on purpose, yous might be fine, but here’s what they do know. Kinda like it’s the right thing to do.
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #27
That was NOT the issue at all; I was more concerned about the TOTAL number of "operability problems" this recall could actually/potentially cause. And yes, I would always want to know about any recalls especially "safety related recalls" from Ford.
Too much $hit controlled by a single item. Makes diagnosing and the cost to fix items related to the BCM absurd. If one thing goes bad that's controlled by this BCM, you need to buy a new BCM..
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #29
@Caster : Well stated!! That is exactly why no one here in this experienced group of ST Owners/Operators has figured out how to totally get ride of the canned exhaust sounds without permanently damaging some other vital function(s). Believe me, I would thoroughly love to take the wire cutters and totally disable that farce/fake/stupid interior exhaust noise!!!!!
Chairborne Ranger
2025 Ford Explorer ST
#30
I have finally gotten this recall issue fixed but it wasn't easy. The dealer first had me bring my ST in on 5 January and concluded that it would need a replacement BCM which they ordered. About a week later they contacted me to install the new part and I brought the vehicle back in. About 30 minutes later the service manager told me that Ford sent the wrong BCM and the correct part was on nationwide backorder. A few weeks later the right BCM came in and we scheduled an appointment for yesterday to install it. After about 30 minutes the service manager comes out and asks me if I have the SECOND KEY FOB! Apparently they need BOTH fobs to do this job but I was never told this either of the two prior visits for this recall. I live 40 minutes away and had to drive home, retrieve the second fob and drive back. Install time was about 90 minutes. Be aware if you are bringing your Explorer in for recall 25C42 you will need both of your key fobs to get it done.
That FREAKIN SUCK! Sorry you had to deal with all of that.
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #32
@Chairborne Ranger :
Great Scot!!!! Many thx for the heads up on the second FOB requirement.
I started this thread on 18 Oct 2025 when I first received the recall notice. On 15 Dec 2025, I took my ST in for it's one year service (12mth/10k mile) and was mistakenly thinking they could fix it then. I was originally told replacement part(s) were available. My Service Advisor completed the necessary forms to notify FORD of my request; She advised that the repair is "VIN# specific" so the specific replacement circuit board (or whatever)would have to be made and shipped to the Dealer. That was seven plus weeks ago!!
Chairborne Ranger
#33
@Nascarbilly, you're welcome. I don't want anyone else to have to waste their time if their dealer forgets to mention the second fob requirement. The recall notice from Ford also fails to mention the need to have both fobs present for the BCM install.
As frustrating as this experience was, I'm getting service from a different dealer than the one I purchased the ST from. At least these guys are more proactive and actually monitor my SUV's status and contact me to get recall work done. I had to beg the dealership where I bought the ST from to do the Customer Satisfaction Program 25B02 Powertrain Control Module software update. They argued since I wasn't having any symptoms that I didn't need to bring it contrary to the notice Ford mailed to me. When I finally got them to schedule me, after I waited for two hours the service manager told me I was ready to go. When I asked him if the software update was completed he said it turned out I didn't need it. Ford Pass kept showing 25B02 was pending and when I went to the other dealer they immediately said when they looked up my ST that I indeed needed the update and did it for me. I'm never going back to my original dealership. Good luck with yours; I'm not sure why it's taking them seven weeks and counting to get your BCM as it was less than two weeks for mine.
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #34
@Nascarbilly,
. . . . . . . Good luck with yours; I'm not sure why it's taking them seven weeks and counting to get your BCM as it was less than two weeks for mine.
Great observation; makes you want to scream, doesn't it?
msrobi
Seffner, FL
So, I have a 2025 Job 1 build and was waiting on doing my recall, since the dealership kept saying that the module wasn't available.
On Sunday, I hit the Auto Hold button and I got a "Auto Hold System Failure" message. I went into the Ford app and I see there's a message about the Hill Descent failed too. I looked it up and this is all related to the recall.
I called today and the dealership says they can see it on Wednesday. They said they would likely have to do a rush order from Ford for the part. Good news is they said they would give me a loaner / rental while they do the recall.
I've read that it can take up to 3 weeks for Ford to get the part to the dealership. So, hopefully it's faster than that.
Nascarbilly
Nascarbilly
Sacramento, CA
Thread Starter #36
@msrobi :
BEST WISHES!!
I took my ST in to the Selling Dealer on 15 December 2025 and they had to order the necessary part(s). The fix was reported to be a completely new replacement circuit board from FORD. I was told it could take a month or more to be made (for your specific VIN#) and shipped to the Dealer. Still NO word on the part(s) from FORD, I checked with the Dealer last week.
