Engine replacement TSB - misfire, CEL
Va
https://ford.oemdtc.com/7822/custom...eplacement-2021-ford-explorer-lincoln-aviator
Certain 2021 Model Year Explorer/Aviator All-Wheel-Drive Vehicles Equipped with 3.0L Engines Engine Assembly Replacement
All of the affected vehicles, an oversized right-hand exhaust camshaft journal was installed in the engine assembly. This may result in a misfire and low compression condition. The check engine light will be illuminated
Yellowknife, NT, Canada
LIke the RS all over again?! A 19 hour job! WoW!
I'd say that's a pretty good supplier screw up and even worse if Ford produces them.
