I had a CEL come up. I will be doing a code check later since I’m at work. I wanted to get a head start on a little research and see if other people had problems similar. Car ran and started fine. Nothing abnormal. This is what FordPass says:
I thought about dropping my car at the dealership to get it replace under warranty But it was easier for me to replace the part myself in under 20 min.
I have P0496 EVAP System High Purge Flow and P0456 EVAP System Leak (Very Small Leak). I called the dealer and they told me it was probably that evap purge valve you linked however it was not covered under warranty and they quoted me $500.
I'd get a Motorcraft valve. Can order one from Tasca Parts. My experience with cheapo purge valves that i installed (not my choice) on other cars is they tend to fail again pretty early.
