EBC Greens and Rotors
Durham NC
just looking to see if anyone is running EBC Greenstuff pads with a Slotted, Cross Drilled or even a cross drilled/slotted rotor.
if you do what do you think of it on the ST?
I currently run slotted cross drilled rotors with ebc green stuff pads and i love them on SHO.
just curious what setup everyone may be using to increase performance in the braking department.
i am looking to replace rotors and pads soon as the rotors are warped.
thanks in advance.
Chaseg08
Golden, CO, USA
I can't find fitment for an Explorer ST. You sure they are made for us yet?
TurboColtGT
Durham NC
i have the ebc green part numbers. i just wanted to change out the rotors with a cross drilled slotted rotors while i was getting dirty.
I know Powerstop makes a slotted/cross drilled rotor for the ST base and Street Pack. They also make coated blank rotors.
I MUCH prefer Hawk 5.0s over EBC Greens. In my experience they have longer life and much better initial bite. I'm running the Hawks with drilled/slotted rotors and loving it. That being said, I do no know if Hawk makes a pad for OEM explorer calipers as I have an aftermarket BBK. If Powerstop makes an aftermarket rotor--I would probably run a slotted powerstop rotor with their ceramic pads.
