Driver seat creaks and moves
Anyone had an issue with the drivers seat in a 2025 where it creaks when you shift your weight and it feels like it shifts side to side when making turns and your weight shifts in the seat? Took it to my local dealer and they said they found no issues but it’s definitely an issue.
Minnesota
2026 ST
Yes, my 2026 does the same thing, there is a TSB out for slightly older ones and the fix is as backyard mechanic as you can imagine. Having said that, I'll likely do it on mine, it's annoying. https://www.tsbsearch.com/Ford/22-2100
N
nulspec
That’s a crazy fix but I guess it works. I’ll have to give it a try and see if it actually works. Not sure if it’ll deal the the creaks the seat makes but I guess we will see. Thanks for the info!
