Confused about Zen integration module
St Louis, MO
So… I have the power and ground wire run and for today I tasked myself with getting all the speaker wires run to locations. Third row is out, and then I saw that I can get to amp easily so thought to just 'bundle' putting the zen unit in today. This thing is not as plug-and-play as I thought it was going to be. I've already called navtv and was told that I need to power and ground the unit from the same place the amps are being powered and grounded from (even if I'm only using the optical output). But at this point I can't even figure out where the plugs are supposed to go and was hoping the experience from this forum could help me out.
In the amp (dsp?) image I'm assuming the yellow-green unit is the amp, is the magenta unit next to it the dsp?
In addition to that… none of the plugs appear to be the type that provides source to the zen unit (blue plug). zen.jpg
The way I'm understanding the harness… I've got a plug that goes into the zen that provides constant, ignition and ground with an additional constant (red/silver)? I really thought the other plug (where?) was going to plug into the amp unit.
If anyone can help point me in the right direction I'd be SOOO grateful. 2025 ST w/B&O.
C
St Louis, MO
Okay… didn't realize what I was looking at was not the amp, it's BEHIND the subwoofer.
