Clicking/Clunking under driver side floor
Katy, TX
You'll have me listening to my Ford every time I pull up to/away from a red light for now on.
They were not able to correctly identify the problem? But it is related, somehow, to how full your gas tank is?
Yes, and it happens in every ST regardless of build date. When your tank is anywhere between 5/8 - 7/8 full, you’ll hear what sounds like a clunking, but it’s the gasoline sloshing around in the tank that’s causing the noise and feeling. I’m not sure why Ford doesn’t think to put additional dampening between the tank and chassis, it would be an easy fix.
David L
Detroit, MI, USA
#42
Did anyone get answers on this my 2021 is doing this with 600 miles
I have wolf hearing and my 2020 ST does not have any fuel tank related thuds at any fuel level. Neither did the previous 2020 ST I had. I do have the constant clicking from beneath the drivers seat while the vehicle is in motion which has been addressed by a Service Bulletin elsewhere on the forum.
GTP
Indy
#44
Mine had a sharp rapping sound from the outside rear. Found a loose final exhaust bracket. I wrote up the repair on this forum somewhere.
KegsBdry
WashDC
#45
Ditto
Virgina, USA
TBD ExplorerST
#46
Reviving this gem. I have a 25' and at low slow speeds, stop and go,I get a odd thud or clunk with what feels under the driver floor/ under my seat.
Anyone get confirmation this is coming from the fuel tank? Mine's 3/4 full atm.
#47
Check the bolt that goes through the sub-frame to the left rear engine mount. I had this issue after they worked on my vehicle and come to find out, they stripped the bolt. It wasn't until we were under it doing something and I noticed this:
The "clunk" had stopped so I wasn't looking for it anymore. The clunking was from the engine flexing up and down until it finally jumped on top of the bolt. May not be your issue but, it's an easy check just to be sure.
