Charging error and battery saver issue
Shawnb01
911 Dispatcher
Connecticut
2020 Ford Explorer
Hello,
Looking for advice or anyone who has has a similar experience. I have a 2020 explorer. Recently I have been getting the system in battery saver mode message. I had the same problem a few months ago, the dealership replaced both the battery and the alternator. The car was fine until the end of September before the issue started again. Now not only am I getting that message when I go to start the car intermittently, but I am also getting a message saying charging system error. When I read the codes, I get 2 different codes one reading as powertrain control system low battery voltage and the other says all wheel drive module system voltage is high. I tried charging the battery which gave an initial reading of 12.3V and when the charger said done said 12.5V. Now on top of it I was driving at night a couple times and all the interior cabin lights plus the infotainment screen, and the dial lights for the HVAC all went out. The dash does stay lit. There's been a couple instances where when the auto start/stop activated, and then when I'd take my foot off the brake to start driving again, the car wouldn't move, so I had to push the engine start button to restart it again. That gave a message about hill start assist even though I wasn't on a hill.
Its also worth mentioning that as a volunteer firefighter, I do have lights, a control system, and a radio added. These are all separated from the car via a circuit breaker. In the spring after the battery and alternator were replaced and covered by warranty, I was basically told by the dealership that they wouldn't cover anything else because they believe its linked to the extra equipment.
Thanks for any ideas.
Toronto, Ontario, Canada
you need to do a bms reset. look it up. You should always do one after you relpace a car battery. Hope this helps.
Ryan8886
Waterford, Michigan
Hi,
I’ve done a search and can’t find much more than this. Last night I got a message from the Ford app that my ‘22 ST was going into a battery saver mode. I went out and started it up and everything seemed fine but now when I check the app it shows the vehicle as “on”. I just bought the car a couple months ago but guessing it’s still on the original battery. My dealer can’t get me in until next week. I’d just go buy a new battery but if there’s a drain on it I don’t want to kill the new one. Should I be okay for a week???
Mobile, Alabama
2025 Explorer ST 4WD
Given that it’s already three years old, my first guess would be that the battery is simply due for replacement. I’ve seen these Ford OEM AGM batteries last as little as two years, and others make it to seven—it’s really hit or miss. The good thing about the battery saver function and app notifications is that they serve as a potential early warning sign of a weak battery.
For example, my Edge’s battery lasted seven years, but my wife’s Lincoln needed a new one in just three. When the app alerts started popping up, I checked the resting voltage with a tester: the Lincoln was sitting around 12.2V, while the Edge was still much higher (after sitting overnight). I replaced hers with a higher-quality, U.S.-made AGM, and we haven’t had a single issue since.
Edit: I missed the fact you already replaced it. Are you saying you can't find the BMS reset?
Mobile, Alabama
Did you try this:
High Beams 5 times, then brakes 3 times. Is the proper procedure to reset the BMS
1. Push the start button with no foot on the brake pedal
2. Flash the high beams five times, then press the break pedal three times
3. Wait about 2 to 3 seconds you’ll see the battery icon flash two times The BMS System is now reset.
https://www.explorerst.org/threads/bms-battery-management-system.4041/page-2
Kansas
2022 Rapid Red ST
Make sure all that extra equipment has its negative (ground) side leads not connected directly to the battery negative terminal. All current draw must go through the BMS module that is mounted on that negative terminal. Equipment leads should connect to either the vehicle chassis or the chassis side of that BMS module. Failure to do this correctly can cause all sorts of problems.
Ryan8886
Waterford, Michigan
Thanks everyone. Ended up going to a local parts shop. They ran for codes and it was clear. Battery also checked out fine…just needed a charge. Likely my fault. I do mostly very short drives, like 5-10 minutes. Took it for a good 40 minute drive and everything seems fine now. Maybe a slipping belt…will have to keep an eye on.
Since retiring,I take a lot of short trips. Started to have battery issues. Once a week I will plug in a smart charger and it resolved the issue. Just make sure you wire it to go through BMS sensor on negative post.
I do a lot of projects in my garage. With the engine off my ST makes a tone of cycles of clicking and whirring during a day. I have a battery gauge and it generally takes about 30 minutes of driving until the charging volts drop.
Mobile, Alabama
Wonder if key fob proximity creates an issue too?
NE Florida
I know this is an old thread but just wanted to comment regarding key proximity. My buddy is an ase master tech for 30+ years and works at one of the biggest car dealers in my area. They have special battery boxes that have faraday shields to stop the cars from communicating with the keys while they are sitting on the lot. Sometimes the sales people do not put the correct box on a car with the proximity keys and it kills the battery every time. He always tells the sales people to use the right box OR if it was a customer he troubleshoots by asking where they store their key in the house. Some guy with a corvette (I think) was storing it just inside the entry door from the garage. Just 6-8feet from the car. Battery died multiple times. My buddy told the customer to move the key somewhere further away from the car and the battery was fine from then on.
Mobile, Alabama
My wife’s Lincoln lights kept cycling one night in an air bnb. Keys in the kitchen and car was parked on side of house. Dumb. And I cut off the welcome in my f150. Don’t need all of the lights to cut in when I walk outside to grab something.
