Center console- what is this?
MY2020ST
2020 explorer ST
Inside center console under the rubber mat there is a rectangular plastic cover. When I removed it this is what I found. Anyone know what it is?
Desert South West
It's supposed to be used to place the transmission into Neutral, but I could never get it to work.
JSA
Ksa
2020 st
Yes it is.
It's to put the transmission in nuetral without the vehicle being on or using the shift dial. If your battery died and you needed a tow you would use this to put it in neutral. It's very hard to move though!
Bridgewater, New Jersey
my 2022 has a thing in there that helps you set a new passcode to the outside door push pad . If you forget the pass code to get the doors open you can take that little key that's in the key fob and there is a way to reset a new passcode if you dot remember your code.
