Center console compartment lid removal?
tontda
Hawaii
Does anyone know how to remove this lid permanently? I don't want to accidentally break this thing off (just in case I decide to put it back later down the road) attempting to remove this by trail and error.
Blackssr
I was at local car show. I guy had put two wireless charger coils on the back side. He had modified the skin on the back side. Very clean install and power is right there. After that he could lay his and another phone down on the door and fast charge
Did you ever get your answer? Working on attaching a coil charger underneath the door. (Sort of like Blackssr) saw.
SFD295
Sandwich, MA, USA
Take the whole console out, it's not difficult. A few bolts and trim clips. Instructions are out there and in the service manual, which I suggest investing in. You can access the door/cover from underneath the console to remove. I broke it taking it out but it wasn't necessary to remove. I just have no patience and I knew I wouldn't be needing it any further. For my install I mounted a Cencom core control head in the pocket. Power is right there for the accessory plugs. You can use forscan to modify the time out time on them to keep them powered after ignition is turned off. 20210428_170952.jpg
T
tontda
Hawaii
@SFD295 , that's a cool setup. I got too lazy to take apart the center console. I opted for an overhead mount using the Havis overhead console mount for the Ford PIU's. Same bolt pattern footprint and turned out to be a really clean install. P.S. Don't mind my custom button legends on my CenCom controller LOL.
Nine29
Motown, MI
Take the whole console out, it's not difficult. A few bolts and trim clips. Instructions are out there and in the service manual, which I suggest investing in. You can access the door/cover from underneath the console to remove. I broke it taking it out but it wasn't necessary to remove. I just have no patience and I knew I wouldn't be needing it any further. For my install I mounted a Cencom core control head in the pocket. Power is right there for the accessory plugs. You can use forscan to modify the time out time on them to keep them powered after ignition is turned off. View attachment 14609
Nice install! Which module and what settings did you change in Forscan to modify the timeout time? Been trying to find them without any luck.
Miami, FL, USA
2022 Explorer st
Hey guys, not trying to revive an old thread, but where did you mount your amps??
@SFD295
@tontda
911jason
911 Dispatcher
Simi Valley, CA
2022 Ford Explorer
Did you ever figure out how to remove that lid?
