Catch Can Worth It?
Wyoming
2025 Exploder ST
Hello All,
I’m interested in understanding whether there’s any benefit to installing a PCV catch can without simultaneously addressing the EGR system. From what I’ve learned, the EGR system can also contribute to intake valve deposits over time, potentially causing similar issues.
Any insights would be greatly appreciated. If there’s an existing discussion or resource on this topic, please point me in that direction.
Thanks!
Welcome to the forum.
Hello All,
Thanks!
Welcome to the forum! There’s definitely a benefit to installing a catch can, the EGR system really isn’t the main contributor to deposits, and it isn’t a problem so long you’re keeping up on normal mantnance and using Top Tier fuel.
texas
Based on the junk I dump out of my catch can, for me, yes it is worth it.
aborchard76
Wyoming
2025 Exploder ST
Thank you for the response, that is helpful.
aborchard76
Wyoming
2025 Exploder ST
Good to know, thank you!
I installed the J&L and plan to check it around the 3k-mile mark — really curious to see what it’s catching. For what it’s worth, I only run Shell or Chevron 93 octane and stick to 5k-mile OCIs.
aborchard76
Wyoming
2025 Exploder ST
Thank you for the info.
I always use top tier fuel and 91 octane (high altitude).
I get about a teaspoon of oil at 3k miles.
On a direct injected engine without additional port injection my opinion is yes. Heck, even with port you could argue, even without the worry of the back of valve cleanliness, you could gain from a cleaner intake air quality,
I've had a J&L on mine for about 12K miles now.
Haven't really seen a lot of junk. I check every ~2-3K miles and get a teaspoon of clean oil out of it. I know i might see some condensation in the winter, but I really haven't.
Feb update edit: now I see lots of oil/condensation junk with cold weather
CessnaDriver
Active Duty U.S. Air Force
Bossier City, LA 7111
Highly recommend one especially with the direct injected engines. A decent amount of YouTube videos out there discussing why they are more impactful on Fords. Even from my usage it tends to collect a decent amount of oil/junk, I was really surprised how effective they are on the ST.
My first 2 months with it, it was like half a shot glass. I think I moved the interval to 4 months. Will be curious to see what it accumulates.
