Battery cost from Ford
My original battery is 34 months old. The car is going into Battery save mode.
Should I replace the battery or wait?
EDWYER
I would replace.
Try resetting the BMS. I did that to mine close to a year ago. It is 60 months and and still going.
Dphan67
Anaheim, CA, USA
Costco has the best prices on Batteries. Well at least in NJ. My wife’s Murano battery died after 6 years. Most places wanted $176 - $250 for a battery. Costco was $129 + 15 for core return
I used Costco as well. Their warranty is what makes it. Interstate battery, 3 year warranty, set a calendar reminder and swap it no questions asked at 30 months or so, only pay any price increase not a prorated charge. I put these in both our cars.
WOW! I put in a new battery from Interstate about a month ago and it only cost me $79! Yes, it was the right battery! LOL I did get it at cost though.
st8
Bel Air, MD, USA
#26
I’m coming up on 3 years with my original battery in my 22. I get the deep sleep notification maybe once or month or so. Mainly just when I leave my dash cam running overnight and it’s monitoring mode. My auto start stop hasn’t worked in over a year. I know my battery is not at its full capacity, but outside of that occasional deep sleep notification, I never have any issues.
I just had it in the dealer a week ago and they did a warranty test on it and everything checked out. I wonder if I should try resetting the BMS. Is there any reason to not do that on a older battery?
I did the BMS reset. The car hasn't went into deep sleep this week.
I drive about 60 miles a day about 10 hours a week. I know the battery is getting fully charged.
st8
Bel Air, MD, USA
#28
Yeah I drive maybe 15-20 miles a day on average. Not much. Mine definitely doesn’t get charged enough. I try to throw it on a battery tender once every 2-3 months in hopes it helps maintain it. Which overall it seems to be helping. Just wondering if the bms would “reset” things since I started doing that.
#29
I would try resetting the BMS. It can't hurt and worked well for me.
It worked for me about 8 months ago. I was getting the sleep notice every time I parked it. My battery is over 3 years old and no doubt getting close but haven't seen notification one time since the reset.
st8
Bel Air, MD, USA
#31
Well, hooked my ST up to a battery tender overnight to “charge it up” and did the BMS reset this morning. First light, start stop turns on. Very interesting for sure and maybe that’s what I needed to do all along. We will see how long this holds up.
Chamorro85
Illinois, USA
#32
I did have some luck with the BMS reset earlier this year. Now I get the warning for Power Save just a few minutes after parking. No issues starting...but very frustrating loosing the 'touch' entry and having to dig for my key.
Finally put on a trickle charge last night and this morning all the Ford Pass functionality came back. Been sitting in the cold train station all day without a problem. Maybe a reset now will keep the reminders from coming back?
Sunday, Car was slow to start. Pick up a battery from Sam Club.
Duracell SLI48AGM $220 with tax.
#34
I would try to reset the BMS again. I've done mine twice over a period of time.
I ran that in my 11 CTSV. Had the battery 5 years when I sold it and she was still cranking.
Jeppo
Davidson County, NC
#37
Walmart sells an H6 48 battery with a 4 year non-prorated warranty for $180 shipped to your home.
Norman, OK.
2021 FORD Explorer ST
#38
Here’s Another Great Video on Ford’s BMS System.
(*It Also Explains The Need & Reasons Behind Ford’s Proper Charging Protocols For Late Model Fords With the Auto Start-Stop Functionality.):
Chairborne Ranger
#39
This is a great video showing detailed steps, it does pop right off
Wow, that's a lot of work just to access the battery and swap it out. On my last vehicle, a 2019 Mazda CX-9 GT, the battery was sitting right there out in the open when you popped the hood, no scavenger hunt needed. Then you only had to disconnect the negative and positive cables and remove two nuts from the bracket holding the battery in place and that was it; took less than three minutes.
