Autostop Eliminator Causing faults on 2025
Suli
Virgina, USA
Did some testing and I'm getting faults with my 25' ST and the Autostop Eliminator "AE050" model (https://www.autostopeliminator.com/products/2025-ford-explorer-autostop-eliminator). The two faults are:
1. Hill Decent Control (shows in the cluster on startup)
2. Auto Hold (Say fault when I push the button for it in the line of buttons next to the volume)
Removed it, faults went away.
Re-added it, faults came back.
I did NOT plug in a scanner to see what the codes were, but I did just ping the Autostop folks to see if they know. Anyone else run into this issue?
I have a 25' ST with the same AS eliminator. Recent Ford updates have been screwing with the AE eliminator. I am not having the issues you are but at times it hasn't kept the last setting because of updates. The fix is to remove the negative battery cable for about 15 mins or longer anbd then reattach it. That has fixed my issues when the occur.
Suli
Suli
Virgina, USA
Ugh, I'll give that a try as well.
