ABS not available sometime
Hamza
Firefighter
Iraq
Explorer ST
I have Ford explorer St 2022.
Recently, I had a problem after a weak battery. I recharged from a friend's car. Suddenly, a malfunction occurred in the brake system ABS, as several warning signs appeared on the instrument panel and the brakes were lost. When I did a comprehensive check, nothing was found in the brake system or its control unit ABS, but the warning signs were still active and the brakes were lost. After that, I disconnected the negative battery terminal for a few minutes, then restarted it. All the warning signs disappeared and the brakes were activated again. I drove the car for three days and everything was normal, then the same problem returned: the warning signs appeared and the brakes were lost, but this time for longer periods. Even after reconnecting the battery and reprogramming, things remained the same, and the fault scanner did not register any faults in the brake control unit ABS. I don't know exactly what happened because there are no fault codes.
and no any problem with CAN bus,
A confusing and unclear situation. Please help me with a solution to this problem. Screenshot_2025-08-19-07-29-40-695_com.miui.mediaviewer.jpg
New Jersey
2017 Grand Cherokee
Weak voltage can give you strange problems. Good chance your battery needs to be replaced if it was dead or near dead. I would start there before diving into the abs system
H
Hamza
Firefighter
Iraq
Explorer ST
Thank you for your help
I replaced the battery and still same problem
After replacing the battery, did you reset the BMS?
Wondering what scan tool also. If possible, use Forscan or Forscan Lite. I bet there will be an ABS related DTC in that.
If the ABS light is on, there should be DTC's in the ABS module. You will need a higher-end scan tool, or ForScan to pull module DTC's as your basic OBD2 scanner can only pull DTC's from the PCM. Given that the ABS light is on, i would expect to see codes.
If you can post those codes, it would be helpful
