7 Pin Trailer Connector
Brookfield, WI, USA
I use the ST to tow snowmobiles/motorcycles in a enclosed trailer, max load ~ 4000lbs.. I love the towing capability of the ST but I noticed that there is no output on the 12V Aux Charing pin on the 87-pin charging pin. My trailer has indoor lights and a safety brake-away battery that are tied to this connection and they do not work(I previously pulled the same trailer with a JGC and the interior lights worked).
I took the truck into the dealer and they essentially had no clue as to why there was no output on that pin. They referenced a SM that said you have to go through a ignition/brake cycle before output to this pin is activated.. Well that sequence did not work.
They suggested I bring the truck back with the trailer as they have no way of testing the connector.. Seriously???
Anybody have any luck with having output on this pin?
Have you checked fuse #57 under the hood? That's the only thing I can think of checking.
