50K Mile Service
Canby, OR
I'm just about to turn 50K miles on the odometer and want to go through car. I'm going to change the fluids in the front/rear differentials and PTU, change the struts/shocks and change the spark plugs. The transmission was already done so that's good and oil is done every 5K. I'm planning to use OEM fluids, PIU struts/shocks and NGK plugs. Is there anything else I should do?
Something a lot of people forget is to check/change the cabin air filter and engine air filter.
I think you have it covered.
DaHuntah
Canby, OR
I have a K&N cabin filter and S&B intake filters. I clean those at every oil change. Good point though. I was thinking about re-greasing the rear axle splines or do you think they are fine? I had them done at around 30K miles.
