3,500 mile 2026 ST Gets A New Transmission
ManInTheBox
CA Gold Coast
My gearbox felt a little harsh at time I took delivery of my ST back in late November. I finally decided to take it to the dealership and get it diagnosed. After a few days, I was informed that it needed a new transmission. I got the beast back today, and the gearbox is noticeably smoother. I am very happy to have it home. Here are the notes from the Tech that did the work. Pretty eye opening.
EDWYER
Glad you are back on the road.
Wisconsin
Same thing my 2022 was doing. New transmission at 60k. We’ll see how long this one lasts. My shifting is noticeably smoother now.
Los Angeles, CA.
Just dropped mine off at my local dealer. 2020 with 40K miles. Been shifting rough for the last 2 weeks and check engine light came on as well. Still 2 months left of warranty.
MRV568
North Carolina
My 2021 had 124,228 in December 2025 when it got replaced for erratic shifting. My Ford ESP ran out at 125,000 so I barely made it!
MIdwest
OP: Nice write up by the tech! Can you elaborate on "harsh" operation? I've never loved how my 2020 feels if I am just driving at light throttle. It's always felt sluggish and a little erratic. I just don't know how to describe it. If on it hard (or shifting manually), it feels better. Is that normal?
EDWYER
Have you changed your differential fluids?
Check your transmission fluid level, they’re notoriously underfilled from the factory.
MIdwest
I have. Did all driveline fluids 2 years ago at 44K. Now has 58K. Also just had transmission output seal replaced under warranty and they topped off fluid afterwards. Maybe I just expect too much and it's totally normal, lol.
Wisconsin
My new transmission also shifts better with more throttle. Babying it around town and it still hunts through gears way too much. This is the worst shifting vehicle I’ve ever owned and I’ve had plenty. I’ve read that tunes can help the shift pattern, but would put my extended warranty in jeopardy. Maybe the ford tune wouldn’t. I’d consider it only for the improved shifts not for the minimal performance gain. I Love the looks and the motor, but ford failed on the drivetrain.
MIdwest
"hunts through gears" is a good way to describe it. I think that's what I was trying to say. I agree on a tune just to improve that aspect, I've considered the same.
“Hunts through gears” is the Ford 10-speed motto haha.
Bronco2Fan
Ft.Hood, TX
So here's my question. If the ST 10 speed transmission is the same as in my S550 does it behave the same in Drive and Sport? In the S550, Drive skips gears, Sport hits every gear. I can feel it in the S550, but not the ST. Also the S550 has rev match when braking. You can really feel it down shifting.
Ryan8886
Waterford, Michigan
I have a question myself…I bought a ‘22 ST back in September with about 28k on the clock. I had a Focus ST for years before it and was just used to rowing the gears…but over time I’ve noticed a relatively hard shift between either 1st and 2nd or/and 2nd and 3rd particularly when I’m around 1/3 throttle throttle to say pull out of the neighborhood left with some juice but bringing it back down right away. It’s just a really rough shift. Also I’ve always wondered while in Sport mode it refuses to go higher than 7th gear even with an attempt at a paddle shift. At the risk of sounding like a moron because I’ve missed the answer in the 50 or so tranny threads I’ve read…is this normal?
EDWYER
Los Angeles, CA.
Mine is doing exactly what you are describing going from second to third around 1/3 throttle. Dealer had it for 5 days and they said that they ran it while plugged in and it showed them that the transmission was running within "normal parameters". Wow.... I've had my ST for 3 years when it was at 17K miles. It's now at 41K miles and this just started about a month or so ago.
Mine is in 9th gear at 60MPH. That is in sport mode.
Wisconsin
My 2022 1060 transmission had CDF drum issues. Hard and abrupt shifts at low speeds. The tech who replaced mine said all these transmissions will screw up eventually. A design flaw. I was under the assumption this issue was fixed a couple years back(2023?), but maybe not. My new one still shifts way too much, but at least it isn’t harsh. For now 3000k in lol!
