25 ST Steering "sticky" on center & does not return to center on its own (bear-left only; bear-right is fine)
Boise
Boise idaho
Update: "All STs are like this" says shop manager after driving others to compare. IOW, what feels to my like stickiness at center is a feature, not a bug.
Update 2: I now understand better what the car is doing, something I could not articulate to the dealer at first...
The steering wheel does not return to center by itself from bear-lefts like easy lane change, I have to force the wheel back to center. Bear-right is no problem, wheel returns on its own almost entirely. So what I called sticky, is actually a problme of asymetry.
Video of behavior:
Originla post:
Has anyone experienced a unusual on-center "sticky" feel in the steering going straight down the road in ST or any other trim? Did you take it in and did they find a fix?
My 25 ST feels like I have to constantly muscle through the usual subtle corrections continuously made normally subconsciously to keep the car straight at interstate speeds. This is with lane-keeping OFF. The loaner 25 Active they gave me feels nothing like the ST, instead it is fluid and easy to two-finger around the center position. It's being suggested it is the nature of the ST's sport-biased steering assist programming, and others have called theirs "heavy". But it's not that, it is just not fluid in the middle and kinda fights and bounces the wheel back from every small input, so much so my usual one hand 7 o'clock hold gets tiring in short order and I have to ---gasp, hold the wheel with both hands in the most casual driving you would do.
This is my 7th new Ford truck or SUVs since 1996 including a 14 F150 and 17 Expedition both with E-assist racks, and they don't have any on-center weird sticky feel like this does. And I keep the 17 in sport mode and while heavier in larger turns of the wheel it is still fluid and not tiring in the center position after many hours' drive in this road warrior rig.
Dealer has found nothing mechanically wrong such as binding rack and steering shaft u-joints. They are going to try a reflash of the steering controller in case there's an update that improves wheel feel.
I'll be darned if this is "just the way it is" with STs. I love most everything about the car, but this thing that grates on me so constantly makes me consider trading it (getting my wallet kicked) for a Platinum to get the perhaps "lighter" steering (maybe?) and the HP of the ST, if the steering program is anything like the Active trim loaner I've been perfectly happy with except for the less fun and grindier but capable-enough 2.3L ecoboost.
To the dealer staff's credit they believe me, but are leaning toward it just being how STs are, and understanding of my just not liking how the product turned out in this particular detail.
Another little possible "it's just like that" thing is that the wheel does not like to return to center on its own in subtle turns, in either the ST or my Active loaner. This is disconcerting as well.
Any insight would be appreciated.
TW73
Edina MO
I’m having the same issue curious if you figured anything out..?
B
Boise
Boise idaho
Dealer had car for two weeks for this and a transient coolant scent, neither of which they could resolve. (They just did not catch the coolant leak in the act, I am still getting whiff of glycol every so often when car is full-hot and in stop-and-go. Points to heater core hot-mode microcrack...)
The non-return to center issue is weird: slight lefts hold ~10 wheel degrees, slight rights return almost fully but not quite to natual center. My ST and the loaner Active did same exact thing.
Nobody has been able to explain this.
They have a ghost in these machines.
Maybe a complaint campagn is necessary if more people are able to objectively document these issues as a pattern.
To be honest, driving this reminds me of my Mustang GTs and tramlining. Not sure if it's the width of the tires, which I’m all for on higher HP cars, but it tends to follow grooves on its own. That being said, I'm used to it from the GTs and personally like the way it drives. BUT, when I had my first GT, a PP2 with 305's, I felt like I fought it all the time. Once used to it, don't notice.
TW73
Edina MO
I’m getting used to it just don’t appreciate it very much I do have 305/35r22 but it drove exactly the same with the stocks
Yeah, those 305's are gonna follow any uneven road surface, whether you want to or not lol.
Phoenix, AZ USA
'25 Expl. ST, Rapid Red
My 1st ST was a 2020, and it too had this 'stickiness'.. It felt to me as if the steeing-wheel shaft was located in its tube by a heavy-duty O-ring, and the driver had to overcome the friction of this O-ring.. The result of this--and it occurred at all rotations and not just when the steeringwheel was centered--was a jerkyness to lane changes.. I 'solved' it by buying a '22 model (principally for its 2nd-row bench seat), and that one's steering was free of this steering stickiness.. Subsequently I've had a '23 and now a new '25 ST, and neither of those has this stickiness.
I wish you good luck with yours.
Phoenix, AZ USA
My '23 didn't, and my '25 doesn't, both with the same set of 305/40/21 Pirelli A-Ss.. My '23, with 295/35/22s Michelin A-Ss, did try to follow pavement lines AFTER I had lowering springs installed and BEFORE I had it 4-wheel aligned.
If the vehicle "sticks" to one direction or the other after a correction it could be a slight toe out of the front wheels. You could put it on the rack and have it aligned with an extremely small amount of positive toe and see if that corrects it. If it shows any negative toe prior to any correction, I would just get it to zero and see how it drives.
B
Boise
Boise idaho
Thanks all, for the feedback, much appreciated. I am hoping it is a matter of a careful minute adjustment as SugarMouth suggests. The dealer racked it and showed all angles in spec: Total toe +.36deg (somewhat biased + from dead center spec), L camber -0.52deg, R camber -0.84deg.
Caster at "1.01deg" makes no sense and may be a placeholder for an incompleted test.
Just about 1000 miles on it now and no change in the steering behavior, but I am starting to understand the pattern more clearly.
It is best descibed now as a failure of the steering to return to center by itself from a minor bear-left like a non-aggressive lane change. A regular hard left and accellerate results in a seemingly normal self-return to center. It is as though they programmed the assist wrong (but only on the left???), if it is not some subtle alignment thing only affecting bear-lefts.
I made a video for my friends at the Ford dealership with hope to overcome their insistance that "all STs are like this." Unless they truly are designed to stay going left when wheel pulled a few degrees to bear left. But not the right. Yeah.
AI suggests: Verify EPAS calibration, perform the “Steering Center Learn / Torque Sensor Calibration” in Ford’s FDRS or IDS diagnostic tool.
I doubt they did that when Ford had the car for two weeks, and a bad e-rack cal would explain the general weirdness of the steering I think.
Houston
2025 Explorer
I'm having the same issue. I was also told they are all like this and the loaner I was given is in fact, not like this. I also made a YouTube channel for the techs to see a comparison between the two. Green dash is my car, blue dash is the loaner.
A couple videos posted as "Shorts" for some reason
https://youtube.com/@bigseemcgee?si=FoQHi5eBZNeNk-F2
BBST
Big Bear Lake CA
Same issue with my 25 ST. OK around town, but on twisty mountain roads it's really noticeable. Left hand turns have one or two "notches" that I have to force it through to get it back to center. Turns to the right are fine. Sport mode makes a difference but can still feel it. Going to take it in but it's about an hour down the mountain to the nearest dealer so have to coordinate all that.
