25 ST Powertrain Malfunction / Reduced Power
I'm not convinced Ford is sending out wireless updates. My dealer says any updates should be available for automatic updates to my vehicle yet to my knowledge, I have not received any updates. I picked up my 25' in late July.
JLatham
Dearborn, MI
Here is the paperwork from my service:
They found 2 codes P0929:00, and P0929:77
They found there was 5 updates that needed to be preformed on the following modules: GSM (Gear Shift Module), ACM (Audio Control Module), DSP (Amplifier?), CMR (Camera Module?), and GWM (Gateway - Network/Communications Module)
They also noted these codes appeared since Nov 29th 2024. I didn't even purchase the car until January...
ST stands for "Software Trouble"! :ROFLMAO:
D Hummel
Shiloh IL
Thanks for sharing those codes. I had the code "P0929" day after purchase November 2024. Not tracking the later code. First oil change this Monday and will have them test. Haven't had the orange wrench sign show up on the dash since but will have them check anyway. I'll share to determine if my 2025 requires same update.
Tulsa, OK
That's no joke. Quality has went in the tank. Maybe they need to hire people that actually know what they are doing, and care. Ford's warranty costs have soared the last few years.
JLatham
Dearborn, MI
It's hilarious but unfortunately, very true. I'm old enough to remember "Quality is Job 1" commercials. That's not a thing anymore. Got mine back Friday after two weeks at the dealer. They replaced 4WD module, transfer case actuator, and pulled down the wire harnesses; no other issues found. So far so good in fresh snow, but time will tell.
Ford corporate recently pushed this software update to my vehicle remotely without me needing to go to the dealer - imagine that, Ford utilizing modern technology?! Drives so much better. The core of this vehicle is HOT - when it comes to fit, finish and delivery...well, don't get your hopes up to high. Maybe I'm biased. I loved my 2022 which seemed so much tighter (other than the fact the rear differential might detach )
JLatham
Dearborn, MI
My 2022 was way better than the 2025! Yes, even with the alleged one bolt differential problem. A retired Ford employee stopped me at a Love's truck stop over the weekend to ask me how I like the 2025. He owned several ST's and was shocked at my long list of complaints (interior lights don't come on when driver"s door opened, lift gate button doesn't work most of the time, AWD/drive mode failures, overall lack of power compared to 2022, manual steering wheel adjustment, blah, blah, blah).
D Hummel
Shiloh IL
Service scheduled for 17 April 25 for two recall items. Incorrect Powertrain Control Module (PCM) software level??? Haven't noticed any engine/transmission issues but local dealer said necessary.
17 Apr 25: Two software recall updates: Powertrain Control Module PCM Software and Gear Shift Module update. Combined service took around 2 hours at dealer.
Eagle, idaho
I had the same issue.
Wrench symbol, initial message, loss of drive modes, reduced power.
Was self cleared the next morning when I left for the dealership and did not recur.
The dealer was not able to get the message to repeat, but did read the codes.
The dealer did software updates as listed above, resets
ST is operating correctly now, other than:
system resisted getting car play to work, even after several resets,
“forget this device” cycles.
That is working now.
If someone knows the TSB #, it would be good to post it. My dealer could not find a TSB.
