20x9 Wheel/Tire Fitment Question
Oklahoma
Looking to install the following on the 2020 ST
Asanti ABL-30 20x9 +35
Toyo Proxies 285/50/20
Suspension is stock. Anybody have something similar?
I’ve seen 20x9.5 +33 on 285/50/20 that works. Not sure how my setup varies on fitment.
Any input is appreciated.
NorthEast Philadelphia
Should be no issues. I had 22x9 with +40mm offset and 275/40/22 with no issues.
L
Oklahoma
Do you think it would be smarter to go with a 275/50/20 instead of the 285/50/20?
Stock size on the 275/45/21 is D-30.74 x W-10.83 with +37.5. If I go with 275/50/20 it makes it D-30.83 x W-10.83 with +35.
Either size will work.. There are more choices in the 285/50/20 size... But Toyo Proxes are nice for the price in the 275/50/20
No issues here. That's my same fitment you quoted. Go for it. 9" is on the narrower side for a 285 but it will work.
L
Oklahoma
I think I’m gonna with 275/50/20 since it’s the closest to the stock spec.
2020 Ford F-150 Raptor
The difference is minuscule. There would be no reason to go closer to stock wheel.
If you’re going to the expense of aftermarket…why the narrow wheel and tire? 10” should be minimum on these cars…anything less looks like a bicycle tire on there.
