- Messages
- 6
- Reactions
- 4
- Points
- 2
- Location
- Commerce Township Michigan
- Vehicle
- 2025 Explorer ST 3rd run
Quick 10 minute install of the Ford Perimeter Plus Alarm. The alarm module plugs into the Gateway moduse which is located on the front passenger side under the carpet under the dash. Just bend the tab down and push in the clip on back center of the plug. Install adapter cable and wire tie module to the 2 holes on the left side of the gateway module. Get inside drivers seat, close the door, turn on control Power, wait for it to power up, turn it off, lock and unlock doors and then test. Leave vehicle lock doors wait 20 seconds and the try to shake or create a vibration. Should beep once and if you continue the full alarm will sound.
- Show All
