2020 ST with infotainment screen freezing
OMA2020ST
Pompano Beach, FL
2020 Ford Exlorer ST
Hello everyone
I have a 2020 ST that started giving us a frozen screen almost daily a few months. Coincidently, if memory serves me well, it may have started after I attempted to install this:
(Redlake Wireless CarPlay Adapter for iPhone 2026 Wireless Apple CarPlay Adapter Mini Size with Cable USB & USB-C/Type-C Plug and Play Stable Connection and No Delay)
I have to do a forced reset (power button/forward button) that solves the issue temporarily until I have to do it again next time we get the car started. I've checked that our Sync 3 is up-to-date, and when I attempted to do a master reset, after I press the "continue" button it does nothing - it freezes on that too and I have to do a soft reset (above) to get back to the home screen. I've checked the fuse (15) under the drive side and is good. Any ideas on how I can solve this issue without having to spend hundreds of dollars to upgrade the Sync 3? Or, even how to successfully process a Master Reset since it currently freezes when I atempt to do one to see if this reset solves the issue?
Looking forward to any input.
Thanks, team.
If Carplay freezes, then yeah, could be the dongle. They are not all the same. But check to see if you have Sync 3 version 23188. That is the final version. Previous versions were bug ridden.
Try disconnecting the battery for 10 minutes. That may help and is easy to try.
O
OMA2020ST
Pompano Beach, FL
Thank you for the feedback.
I uninstalled that dongle right away when I couldn't make it work.
Also, this is the version I have, and when I checked the latest software it can't back saying that I had the latest update. How can I get version 23188?
O
OMA2020ST
Pompano Beach, FL
Thank you. I'll try that as well.
O
OMA2020ST
Pompano Beach, FL
So, I tried the battery being disconnected for 30 minutes, and I still could not do a master reset. I also tried to do the upgrade via USB, and when I inserted the flashdrive, I saw that it was read, but nothing happenend and the upgrade didn't automatically start. I double checked that I had the right files, also the correct flashdrive (exFAT formatted), and nothing. Any ideas, friends?
The glitch in those old versions can make updating or doing master resets extremely difficult. Back when this issue reared it's ugly head, we were trying updating (USB) immediately after a soft reset. Sometimes multiple soft resets in a row followed by updating.
If I'm not mistaken, there may be a Customer Satisfaction program on this where the dealer will update to 23188 for you. Ford really screwed up with this.
Also, if you are not afraid to use CyanLabs, I believe they have a script on USB that will clear the memory that is causing the problems, so that you can update.
https://community.cyanlabs.net/t/ap...-master-reset-or-upgrades-updates-solved/8858
O
OMA2020ST
Pompano Beach, FL
Thank you for the tip above. I am going to reach out to Ford first before I dare to try that CyanLabs route. I appreciate it very much.
One other thing, did you unzip the folder after you did the download?
If so can you post a picture of the files you have?
Are you able to get into the settings menu on the screen?
O
OMA2020ST
Pompano Beach, FL
Thread Starter #14
oh yes. I can get into it, and when I look at the about sync I see the 20136 build.
O
OMA2020ST
Pompano Beach, FL
Thread Starter #15
Could you confirm that those are the correct files to upload? From what I've seen, the system should be able to autorun but it doesn't work that way with mine.
Have you tried to do a reset by going into the settings? In there is an option to do a hard reset.
O
OMA2020ST
Pompano Beach, FL
Thread Starter #17
Oh yes. I've tried that several times. After I hit "continue" it just stays there frozen, so I have to do a soft reset to get out of it.
I'm out of ideas. I think @Cdubya advice may be the way to fix it. I would check with your Ford dealer first before trying Cyanlabs. Good luck.
O
OMA2020ST
Pompano Beach, FL
Thread Starter #19
I really appreciate your help, brother. Lastly, could you confirm the three files above are the correct files to try to upload?
