2020 heated windshield
Huntington, NY, USA
I'm sure this only affects a very small group but figured I would share. My 2020 had the battery drain issue, the fix was a programming change. After I got my first window replaced I verified it was heated. When I went into forscan to make some changes I noticed the windshield heater was disabled. This may have been from the prior issue so u may want to check if this happened to you.
Peoria, AZ
I've never heard of a heated windshield. Are you talking about the defrost on the HVAC? Or like the rear window with the heater lines?
randyknight
Chelsea, AL
2020's had a heated windshield with elements down by the wipers, just like the elements in the back window. They removed it sometime in 2021.
Peoria, AZ
Ah. I have a 2022. I live in a warm climate, that might be why I've never heard of a vehicle with a heated windshield. Kind of useless in Phoenix, lol.
Where in Forscan do you find the windshield heating option?
DaveG ST
Hurlock, MD, USA
Better to have and not need, then to need and not have.
powerby50
Huntington, NY, USA
I'm loading up a tune soon , so I'll check exactly where it is. I found it when I was doing the Bambi mode, double honk , and Feng. So its somewhere around there.
Bridgewater, New Jersey
I have never heard of that either so don't feel like u are put of the loup !! Thats a new one to me ...
