1.25" wheel spacer, stud trimming
Yea , cutting the lugs isnt the worse thing in the world to do ! You can always knock the ones you cut out and put new lugs in if you change you rims..
I’m aware. I was just saying it’s 1” or less, not “under 1”” like you posted to clarify for people tha may not know.
Orwigsburg, PA
I bought two Eibach 30mm spacers to check fitment, back looks good but the front sticks out a little more than I want.
If I trim 5mm from the front studs and put 1 inch spacers in, will I need to replace the studs if the spacers are removed later?
All factory ST wheels will clear with the 30mm spacers.
Orwigsburg, PA
Yes, 30mm will fit and 25.4mm (1 inch) will need 5 mm cut off the studs.
Will I need to replace the studs if I remove the 1 inch spacers for different rims with the correct offset?
My question is, why not run the 30mm on all 4 corners where they will fit just fine and not worry about cutting the studs at all?
Orwigsburg, PA
They fit, but the front sticks out more than I want it to. I think moving the front tires 5mm in would look better, but if I have to replace the studs when the spacers are removed in the near future, I may just get two more 30mm spacers.
So my question is.. do I need to replace the studs if the 1 inch spacers are removed?
That will depend on the hub thickness of your wheel. If you get 10 full threads of engagement, you’ll be good. Anything less and I’d swap them.
Orwigsburg, PA
Thanks
