Last Call - Show Your ST Photos With Your Stock 21 Inch Wheels, Lowering Springs And Wheel Spacers !!!
Here is the only forum vehicle I have seen so far. Please post your photos here to share other points of view like following directly behind or standing directly in front to see what the stock tires look like spread out further by spacers. Share the spacer width and brand. 20201027_172926.jpg
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
H&R Springs and Steeda Sway bar scheduled to be installed Monday, but here's BORA 1.25" spacers all around.
Before on left After on Right
Stock wheels and tires
Awesome. Do you have any more angles with the spacers? If not please post some once the springs are installed.
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
Lower, Wider, planted, worth every penny, Yes It's dirty, but it's MN in January....
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
And here it is at the dealer next to stock Explorers
Love this Ride, Just had our first purchase anniversary!
BigIsland
Kona, HI, USA
What torque spec did you guys do? Paperwork says call over 140 but ST in 150. Any definitive answer on this?
bmbradley9
EMT
Maple Ridge B.C.
Who cut their studs?? Were you guys able to fit them without cutting??
SmittysST
SOCAL
2023 FORD Explorer ST
The 1.25" spacers can go on without cutting the factory studs correct? How is the ride quality compared to stock with those H&R springs?
SmittysST
SOCAL
lights are on but nobodies home......
