ECM cover.
Did some minor rework on the angles and height. I think this is the final version. Still no screws or bolts…it’s held in place with the wiring harness pins on both sides. I think it’ll look pretty good when I get around to painting everything I need to under the hood. I had an old sticker laying around so I slapped that on there in the meantime. F938549B-A4A7-4954-95EC-95AB404EFB1D.jpeg 389F80FC-6FE7-4032-A338-56D833FDB52C.jpeg
I have a full sheetmetal shop at my disposal. I made it at lunch one day.
30122 Woodward Ave
Ah ok, just seeing if it was something you were making.
Nah…just something I was playing with.
2022 Ford Explorer Platinum
I would buy one if you decided to make a few...
Midwest
If you sell them let us know… I for one would be interested
Ricky
Sunnyvale trailer park
I went with Fenfab. I like how yours contours around the ecu, very nice work!
Safety Harbor, FL, USA
What's the function of the cover? Or, is it just for aesthetic purposes?
Ricky
Did the ST come red like that or did you modify yourself to do so.
I modified it. Just pick a color and cut it to fit under the cover. There is plenty of room. I actually used a small cheap plastic cutting board. It was thick enough and should stand up to the heat, so far so good.
Hudson, NY, USA
I used your cutting board trick. Worked like a charm.
