MBRP with a muffler replacing the X-pipe. It droned like crazy with the X-pipe, now the drone’s like 97% gone except when under 1500 rpm’s it still does a little when cruising, but I’m usually above that rpm range. I might swap out the canister mufflers for the factory rear mufflers. So basically the only thing left from the actual exhaust kit would be the piping
. Still on the fence about it. Most ppl are running the 2.5” Thermal exhaust with the accompanying midpipe and seem to love it. I’d say if the MBRP is on your list take it off, go Thermal or custom.
 - Show All
