Winter Tires 21” Street Pac
pryan
Swanzey
I apologize if there is a thread I haven’t located on this topic. I have a 2021 with the 21” rims. I’m going to keep them for winter and not buy new, just winter tires. I’m finding few options. Mostly Pirelli Scorpion Winter and Nokias Hakkas. Any recommendations from those with some experience?
It's so subjective that only under some rigorous testing could anyone answer your question. Subjectively though, I had Hakkapeliitta snow tires for two winters on an '06 STi in North Friggin' Dakota. If I still lived there, I'd buy 'em again.
2020 Ford F-150 Raptor
I have no experience with them, but I did a LOT of research, and Bridgestone DM-V2 Blizzaks are the best.
Ontario, Canada
I disagree, nothing beats a studded Nokian Hakkapeliitta. We have them on our vehicles here in Northern Ontario. They turn a front wheel drive van into a 4X4 and a 4X4 into a snow beast.
Although it's not common knowledge, Nokian actually builds certain Bridgestone winter tires in Finland and US. Understand that (at least for US studless tires), the US market is different than the market in Finland. If you want a decent tire for occasional winter use- not much snow, not much ice, you care about noise, treadlife, etc. then most of the "winter tires" will probably fit the bill. If you only care about traction on ice and snow, especially if you spend entire 4 month winters with snow and ice covered dirt roads, then the Hakkas are about as good as it gets.
pryan
pryan
Swanzey
I’m in NH. Don’t travel on dirt roads much but the amount of ice/snow depends on the winter. I need to be where I need to be so I want something that I can count on.
You can't go wrong with either of the two you mentioned in your first post. And, I'm sure you're aware, if you get 3 feet of snow, there is no tire on earth that will make a difference!
Ontario, Canada
Unless you are driving a snow beast. Sorry, I mean a snowmobile.
pryan
pryan
Swanzey
If we get three feet of snow I’m pretty sure I’m not going anywhere anyway!!
Penticton, BC, Canada
Explorer ST
Definitely the Hakka’s. I just installed the new generation R5 but with 20” rims. 21’s OEM will be for spring and summer only.
pryan
pryan
Swanzey
Thanks everyone for the replies. I ended up going with the Hakkas for the piece of mind. Paying a lot more but I suppose if they make me more comfortable then they are worth it.
GHB66
2020 Ford Explorer ST with ST Street Pack
Can you share the specs on the 20" RTX wheels that you bought for your ST? I have a 2020 ST / Street Pack and would like to get a set of 20" Wheels and tires that fit my Street Pack without spacers, etc. Thanks in advance!
Explorer ST
The only info I really have on the wheels is the product code etc from Kal Tire. I never research these as my original intention was to get just plain steel winter wheels. The Kal Tire guy just showed me some pics of what would fit in black and I just happen to pick these. Kal Tire product code ( possible that it’s RTX code) AG1237816915 20 x 8 5114 gloss black TAG RTX V20 083053. That is the entire line on invoice of the wheel . Hope that helps .
GHB66
Thanks! That helps.
pryan
pryan
Swanzey
Thread Starter #15
So I got the Hakkas and when I got home realized they came studded. I hadn’t really looked at the tire place. Now I need to decide if I’m going to keep them or gripe because they were specifically NOT supposed to be studded.
The studs are hands down better on ice. Studs are tough on concrete and murder on epoxy garage floors.
Explorer ST
I’ve had studded Hakkas two previous times before and with their new stud technology are excellent and much quieter than the typical studded tire. If you didn’t pay the extra 50 or so a tire I’d keep them. since You drove all the way home and didn’t notice I’d say they are ok noise wise. I only switched back to Hakkas non studded due to the fact I need winter tires on for 7 months of the year due to requirements on BC interior highways. In city I prefer non studded but mostly my wife prefers them
Yellowknife, NT, Canada
I think you have the best possible winter tires one can buy. Coud be the difference between sliding past a stop sign or stopping safely.
Columbus, MT, USA
I'm leaning toards slapping on a set of Pirelli Scorpion Winters on my OEM rims once this winter is over and run a new set of 22's for the summer and the OEM with winters for the other 5-6months
Ford Explorer
#20
Has anyone considered the new Pirelli Scorpion WeatherActive tire instead of a swap to winters and summers. I am getting set put on my 21's on Thursday but was hoping someone else had looked into them too.
