Forgot to mention the installation of the Mishimoto oil catch can kit which was quick, easy and well designed.  I did appreciate the included hoses which fit like a glove.  I had some concerns about the space around the catch can and if I would need to pull the whole unit out to open the catch can itself that I had reached out to Mishimoto about before purchasing and never heard back on but went ahead and ordered it anyway. I’m happy to report that the catch can can be removed without having to pull the mount and hoses.
I also put on a set of TVD’s vinyl decals for the embossed door panels and if one follows the instructions, they go on fairly easy.  The first side took longer than the second as I was making adjustments in how I was doing it as I went along and improving how I was getting the decals off the card and applying them to the embossed letters on the door.  Ended up not trying to put the letters on in spelling order but how they sat on the card.  Pulling the letters from left to right off of the card using the tape and then applying using the soap solution method that TVD describes. Having good light is a must to get them seated correctly.  Went with a blue to get close to matching the ST’s Atlas Blue color and while subtle, I think they look pretty nice.
