Stumble/rough idle
NJ
Truck only has a little over 2,000 miles on it, and at idle it stumbles a lot, and almost feels like it is gonna stall... Making an appointment with the dealership now, but has anyone else run into this?
TexaST
Dallas, TX, USA
Mine will do this on occasion but only after a cold start. It’s usually a rough idle that seems to be coming from the flex pipes in the exhaust.
A
NJ
Mine is happening when warm, and in gear.
Jacksonville, FL, USA
I get this every once in a while. Usually when engine is warm after driving quite a bit and stopped at a red light. Almost feels like a mild cam haha
A
NJ
So it is related to the a/c... No a/c it idles fine, regular a/c it stumbles a bit, max a/c it barely idles now. Time to bring it to the dealer I guess.
Moline, IL, USA
So what did you find out? Is the rough idle a fixable issue?
Sbenis
Mesa, AZ, USA
Mine does a rough idle also while in gear
Safety Harbor, FL, USA
A little late to this thread but mine idles rough when the AC is on. Did you take yours to the dealer?
