Rear-End Squeak - Steeda Anti-Sway Bar
Marietta, GA
2025 Ford Explorer ST 4WD
My ST squeaks like crazy over bumps. The dealer says it is the Steeda sway bar that is causing it. What is the best lube to use to eliminate this noise?
R
Marietta, GA
I loaded it up with grease during the install. I installed in MAY; when colder weather arrived (SEP), the squeaks started.
My plan is to drop the bar and re-grease... with what is the question... that you answered!
Gadgtfreek
Gotcha. I'll be curious to see what happens with mine. Odd thing is, one line of thinking is don't grease it at all, and greasing makes it worse. But I don't know enough about the material to argue either way.
I keep a small tub of Energy Suspension silicone grease in the garage. There’s nothing better and you can get it at O’Reilly
You always grease urethane bushings.
Gadgtfreek
That's one I read about today.
Super Lube Multi-Purpose Synthetic Grease w/ Syncolon. My go to grease for bushings.
R
Marietta, GA
Issue Resolved. I finally uninstalled the Steeda bar, cleaned it, cleaned the bushings, and then put entirely too much silicone grease on each bushing and the bar. I was certain to grease the stop ring near the bushing as well. My truck is blissfully quiet now.
Thanks to all.
ARC
Oak Lawn, IL, USA
2022 ST Black
Had my Steeda bar on for about 45k - 50k now and it finally started squeaking. Was going to regrease until I saw the corrosion on the bar. I had the same problems with the Steeda lowering Springs, so I replaced with Eibachs. (Steeda did replace the set under their warranty) Anyone know the part number fir the PIU rear sway bar?? I think I may just go with that now.
