Does my 26 st have a gpf
Minnesota
2026 ST
Yeah I spoke to thermal and looking forward to to that. Going to install the cvfab intercooler and downpipe next week. I spoke to the guys at cvfab and they said their downpipe will be fine with the gpf. Can you guys confirm that?
None of us would likely know, you're the first I've seen here with the GPF, I'd trust CVF's word over any of our opinions, which is all we have at this point.
St. Louis
For the 2026 model year, Ford has introduced Gasoline Particulate Filters (GPFs) to certain EcoBoost vehicles, including the 3.0L V6 engine available in the Ford Explorer ST. [1, 2, 3, 4, 5]
Why Ford Added the GPF
As part of increasingly strict global and regional emissions standards (often referred to as "green state" requirements), Ford is rolling out GPFs across its lineup. The GPF acts like a diesel particulate filter, capturing fine soot and particulate matter directly from the exhaust stream of your direct-injection turbocharged engine before it exits the tailpipe. [3, 4]
Impact on the 2026 Explorer ST
• Vehicle Compatibility: Depending on the exact production market, some 2026 Explorer STs roll off the assembly line with a GPF equipped from the factory.
• Aftermarket Limitations: If you are shopping for aftermarket parts, such as an exhaust or cat-back system, you will need to pay close attention to GPF compatibility. Installing an exhaust designed for a non-GPF vehicle onto a GPF-equipped model will likely trigger a Check Engine Light (CEL) and require custom tuning.
• How to Check: Because only certain regions or batches get this filter, you should look up your Vehicle Identification Number (VIN) with your parts dealer or check the Vehicle Emissions Control Information sticker under your hood to confirm if your specific model has a GPF. [1, 4]
AI responses may include mistakes.
*Market specific is interesting.
Gadgtfreek
There is also a big write-up on the 3.5L F150s.
Trying to find the post, but I believe it was posted elsewhere that the cut-in date for the GPF was around the mid-April timeframe.
50CalLabz
New York
2026 explorer st
Thread Starter #25
So the funny thing is my local ford dealership said that I can swap out the exhaust and it’s not a problem even with it having the gpf (they’re definitely misinformed about this) but I did verify with the guys at cvfab that I can do their downpipe with no issues. I just have to wait on thermal to release the new exhaust for it. So downpipe, intercooler, intake and tune it is for now. Should have everything installed by the end of next week
AST8U
houston tx
2026 FORD EXPLORER ST
#26
I just ran outside and checked mine it does not look like that at all. SOOOOOO all in all im pretty happy about that. I guess when it comes around to doing whatever I will be doing I can just do it ......Like NIKE
#27
You guys that have the GPF....what states are you in?
Is this a regional thing like CA-only, or is every state getting the rollout
#28
Every vehicle will be getting it.
#29
4/13/26 build date forward for 17 CARB-adopting states plus Washington D.C., including: California, Colorado, Connecticut, Delaware, Maine, Maryland, Massachusetts, Minnesota, Nevada, New Jersey, New Mexico, New York, Oregon, Pennsylvania, Rhode Island, Vermont, Virginia, and Washington.
Check the VECI sticker under the hood (it will list "GPF" if present)
Source: GROK
Fort Lauderdale, FL, USA
I just got a 2026 in Florida that was built in May. I had NO IDEA about this and now I’m bummed out. Mine has the GPF also. Is it possible to remove this? If I got an Xpipe or Hpipe would it delete this? Any sensors to trigger a check engine light?
#31
I’ve seen the Ford Authority article claiming this is state specific…but I’ve seen folks also in “exempt”
States chiming in to say that they have the GPF.
Someone in Ohio also had a GPF despite not being on the list of states that are supposedly the ones to get it
Ya I’m in Florida and it’s there haha
the whole exhaust system is so much different than what I remember on the 2022, the actual center muffler is way back towards the rear axle when I feel like it used to be closer to the downpipes before
#34
I see where it says that, but then the following paragraph contradicts it, unless including 2026 is a typo.
New Jersey
2017 Grand Cherokee
#35
They come with Gay Pride Flags now?
