Shaking dash with AC max
Milwaukee
I had a really strange happening yesterday. I switched the ac to ac max and 1 min later a thump and the dash was shaking/going crazy. I turned the ac down from max and it lowered then entirely off and it stopped. When I got home I started the car up and turned the ac on again and its fine. Didn't test max ac as I was still a bit hesitant. Mi d you it is about 100 degrees out.
My thought is the max ac created too much load and made the belt slip n shake the world. Any other thoughts? Should I get this looked at?
If it does it again I’d have it looked at, if not, then no.
EDWYER
I'd get it checked out.
New Jersey
2017 Grand Cherokee
Wonder if it was the mixer or whatever it’s called that pivots to change the airflow inside the hvac system. That can get stuck and make a loud grinding with a little shake. Try changing between outside air and cabin recycle next time it’s on and see if that makes any noise
P
Milwaukee
Took it in. Turns out there was a big mouse/rat nest blocking air flow. Luckily no wires were chewed up....rats nests aren't under warranty but could have been much worse
EDWYER
Forgot the good ole mouse/rat check lol
