Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
I moved my P3 vent gauge into the blue cruise eye sensor for a 2025^ Explorer. I should’ve done this a year ago when I first thought about it. View attachment 35064
@UNBROKEN :
You are a very talented guy!! FORD should hire you as a Consultant to help improve the overall quality of their performance vehicles. If the ordinary ST could be a better vehicle from the start 1) the buying customer would get more for their money 2) "Lookers" would turn into buyers/owners and 3) FORD's bottom line profit sheets would benefit too.
BTW: I'm still waiting on you to crack the nut and get rid of the fake engine noise without damaging any other functions. No pressure!!
MO
2026 ST AWD
Fellow STers,
Today I did the first oil change with 1,137 miles on the clock. Filled with Mobil 1 5W-30 and a Motorcraft filter. I put in 6 quarts as a start and will check the level after a drive tomorrow.
FWIW, the drain plug (2026) has a 10 or 11 mm bolt head in the center and it was not a problem to loosen. Glad I didn't need my spare (it has a 3/8" square drive recess in it). The OEM plug has a central passage and drain hole so the oil can be drained slowly without fully removing the plug. It took about 3 minutes to drain and only a fine line of oil drained after the plug was pulled out.
JLT oil catchcan had about 2 teaspoons collected after 700 (pretty gentle break-in) miles.
That's it for today. :)
DSGR
Wilmington, North Carolina
I've contacted Fenfab over the fitment issue with my 2026 ST and his cold charge pipe. He has yet to respond and I doubt he will. He's determined he's right and I'm wrong. I guess it's on to the BBB. I called S&B and they have provided me with excellent support along with my order of their cold charge pipe. They requested some photos and a description of the fit since they advertise it to fit up to a 2024 Explorer ST. There are differences and it doesn't seem that anyone makes a cold charge pipe that is an exact fit at the intercooler outlet on a 2026 ST. I drove our '26 ST today after installing the S&B cold charge pipe and it did fine. If anyone has installed the S&B part on their '26 ST, please let me know and how it's going so far. Does anyone know if there is an exact fit cold charge pipe for a '26 ST? I'm thinking about the rear differential brace and brake upgrades by Brake Performance. I've used their slotted rotors and ceramic pads and they have been the best brakes I've ever used!
DSGR
Fellow STers,
Thank you for the info. I recently purchased a '26 ST and am planning to change the oil at 1,000 miles. I was wondering about that oil drain plug. I guess it's still plastic?
MO
2026 ST AWD
@DSGR,
You're welcome. Yes, the plug is plastic. It did not take much torque to loosen it (the tabs will flex over the stops). Even though the hex protrusion has a slot for a screwdriver, it is safer (imho) to use a socket - more surface area to spread the applied force and less chance of the tool slipping.
I picked up a replacement plug at the dealership and it has a 3/8" square indent in it. I don't know if this is a newer plug than the OEM plug. The 'emergency spare' plug looks shorter, too but I failed to put them side by side to compare.
Once the plug is loosened, don't pull it all the way out. Hold it in place and let the oil drain out at a gentle rate. A little higher flow can be had by by tilting the plug in the drain hole. After a few minutes, most of the oil has drained and the plug can be removed. I let the pan drip for 30 minutes or so after removing the plug - probably not necessary to wait that long.
Removing the top of the (stock) airbox opens up the work area to remove the filter. The air inlet tubes come off and then it takes a little jockeying to get the lid off (and to reinstall it). Have a rag ready to put under the filter.
I poured a little fresh oil on the new filter (don't go wild, just get the filter wetted). Don't know if that is necessary but old habits die hard.
HTH.
DSGR
@DSGR,
HTH.
Yes indeed...it helps a lot and thank you! Are you considering an aftermarket oil plug from somewhere like UPR? They have a variety of oil plugs with a couple of them with drain valves. I'm doing the first oil change at 1,000 miles. I was debating about using one of their oil drain plugs.
Quite like my UPR drain valve.
MO
2026 ST AWD
Howdy, DSGR,
I have looked at the UPR drain plugs and like the simplest one - it has a cap without the quarter-turn drain and hose fitting features that most of them have. But the OEM plug was easy to loosen and tighten, it stays in plays, and it is designed to drain the oil (slowly so there's no mess). I will keep it for the foreseeable future. (No need for an aftermarket plug if a [future] metal oil pan replaces the OEM pan.)
MO
2026 ST AWD
GearHead_1,
That's one of their "speed" plugs - very nice!
Does it use the 'wave washer' or does it lock on another way?
I'd be concerned about losing the little dust cover. I would order a spare or two since I am sure that I would eventually drop it onto the garage floor, it would bounce in the direction I was not looking, and I'd find it months later. [chairfall]
Gulf Breeze, FL
26 Explorer ST, 21 Bronco, 24 Ranger Raptor
I've got this drain plug on 3 of our Ford vehicles... Explorer ST, Bronco, and Ranger Raptor. Hands down one of the best upgrades... makes life sooo much easier when changing the oil.
MO
2026 ST AWD
Bronco2Fan,
Link: UPR oil drain plugs
You're right that their site does not list them for 202x STs but the plugs fit Broncos and F150s so they will fit STs.
HTH.
COBRA90GT
Metro Detroit
Changed the oil. :cool:
Nunya
Finally got a tune in! ZFG DMS 91 at 6,000ft altitude made almost 21lbs. She pulls hard. This is just the base tune and needs revisions.
Nunya
Link? It doesn't show up when I search. Says it doesn't fit 2026 Models.
For what it’s worth, i bought one of these plugs then got a harbor freight extractor/dispenser pump for like 120, and i will never go back to using the drain plug. Since the oil filters are on top you can change oil without a drop spilled with the extractor
DSGR
Howdy, DSGR,
Thank you for the pics. I have about another 425 miles to go before reaching 1000 miles, when I'll do the first oil change. I'm still deciding about the oil drain plug.
Winnipeg
Explorer st 2025
Thank you for the
Mines done 6650 miles and still has 28% oil life left before it's first change is due LOL
If it was mine the first oil change would have been done a while ago. Most people change at 5000 miles or even less.
Hull, GA, USA
Got a new diff put in today at 58k. Dealership charged $3200 and ford assisted with $1200 out of warranty. I guess I’ll be changing the rear differential fluid more often and hopefully that helps.
