Ford Connect navigation sound issues
ST2025
PA
Took to dealership for this issue and they didn't fix the situation with the voice prompt volume.(maybe too new)
I fiddled around with the system for awhile and got the voice prompt volume to work again. All I did was turn on Apple car play(voice prompts were not working on apple maps either). Then I disconnected apple car play and the voice prompts started working again in Google maps. I hope this helps.
M
mk1963
Thread Starter #22
Yeah, mine worked temporarily after clearing cache and storage doesn’t. It’s back to low volume. Thinking about trying factory reset.
ExplorerSTLine
Pennsylvania
2025 Explorer ST-Line
FWIW - Google Maps Volume Control Problem - I have tried all suggested solutions - they all work for a day then goes back to "low volume." My net searches indicate this is a widespread problem. I went through a OTA the day before yesterday and it started working. However, the next morning - low volume.
Well, some good news. After the last "low volume" I decided I wasn't going to try fixes any longer - going to wait for Google Maps to fix their problem - it happened. The morning after the low volume - it went back to normal. I didn't do anything. Today is the second day in a row it is working just fine. So, maybe - just maybe Google fixed the problem.
M
mk1963
Thread Starter #24
That would be nice if it is fixed. I used mine yesterday and it started out fine and by the second instruction it was back to low volume.
ExplorerSTLine
Pennsylvania
UPDATE Day 3 and volume is working perfectly! UPDATE
M
mk1963
Thread Starter #26
I haven’t had a chance to try mine yet. I’m really hoping mine works too!
ExplorerSTLine
Pennsylvania
#27
UPDATE: Just realized I have been getting OTA Updates (4 within a few days). One thing I noticed - after a OTA the volume problem goes away BUT comes back a day later. Maybe, this was causing my volume to work one day and not the next?
  1. ABS-25.AR (04/14/2026) - Brake Pedal Alert
  2. BCM-25.6.0 (04/13/2026) - Remote Commands
  3. TCU-25.2.8.5 (04/11/2026) Update 11 - Connectivity
  4. PHX-25.1.2.5.5 (04/09/2026) - Center Touch Screen
So, that may be the reason Google Maps Volume Control problem seems fixed. I will have to wait for a few days with no further OTA updates Will report back in a few days.
M
mk1963
Thread Starter #28
M
mk1963
Thread Starter #29
It will be interesting to see what happens when you stop getting updates. I wonder if the updates do some sort of reset that make it a temporary fix. Can’t really find technical information on the process.
ExplorerSTLine
Pennsylvania
#30
FWIW - I am convinced that the OTA (and other procedures that have you clear out cache/storage) clears out memory. Anywho - if it still works tomorrow morning - I will be convinced that it is now fixed. I will update my findings.
ExplorerSTLine
Pennsylvania
#31
UPDATE: 2nd day and Google Maps Volume Control is still holding good volume.
M
mk1963
Thread Starter #32
That’s good news. Hoping to try mine out later this week :)
STTuner
United States of America, Utah Orem
XLT
#33
Hi everyone,
I have the Ford Connect and when using Google Maps the navigation sound isn’t working correctly. The volume control while the voice is speaking does nothing. Maps is not muted. You can hear the directions but the volume is about a 2. The settings show the volume at 20. Did the test in map settings and you can adjust the volume just fine. It will be the correct volume for 1 or 2 turns then it’s right back to super low volume. Can use Google Maps with Car Play and it works fine. Any ideas on what is happening or how to fix? Any suggestions would be greatly appreciated. I have a 2025 Explorer ST with Sync 4,
Yeah I’ve seen something similar on my ST with SYNC 4. Sounds like a software bug more than anything since CarPlay works fine.
Try doing a full system reboot (hold power + seek forward until it restarts), then check for any SYNC updates. Also while the voice is actually speaking, adjust the volume again sometimes it only locks in during the prompt, not in the test menu.
If it keeps dropping back down after a turn or two, I’d bet it’s the nav audio channel glitching out. Might need a dealer flash if the reset doesn’t stick.
ExplorerSTLine
Pennsylvania
#34
FINAL UPDATE Day 6 and volume is still working perfectly! UPDATE FINAL
...CASE CLOSED...
M
mk1963
Thread Starter #35
I was able to try mine yesterday and it worked as well. Glad to see yours still working after 7 days.
