ManInTheBox
CA Gold Coast
While not a fan of folks accessorizing the interiors of their rides like a Filipino taxi, I took a chance on these pedal covers. I was surprised at the quality and fitment for the money. I think they nicely enhance the cockpit of this performance vehicle.
https://www.amazon.com/Hecotrax-Explorer-Performance-Accelerator-Accessories/dp/B08MT5MC4W
Have the same. I found the brake pedal needed some heat to get the flap properly installed. Mine have held up great so far. UNBROKEN probably has 100k on his and I think they are good to go.
Troll much?
Gadgtfreek
LOL. Good morning, entertainment.
EDWYER
Alignment done at Ford after Eibach springs.
Yup, looks good. The dealer I bought my ST from could not get my alignment done after springs. They had no clue about the rear upper inner bolt. Any the ST’s had been out for two years when I bought mine
MO
2026 ST AWD
SugarMouth,
My, my, those are some huge meats. Beware of Vette owners lurking around your garage in the wee hours of the morning.
What sort of offset is needed to make those fit with no rubbing? What wheels are you planning to get (or have gotten)?
Your ST is going to look mighty fine with the new socks and shoes.
SugarMouth,
22x10.5 +30 Rolling the dice on Alibaba. Maybe here toward the end of the month.
Did some fine tuning on the dash midrange install. Last step will be having the dash mat hemmed where in had to cut it around the pods. This project is 99% done. IMG_9495.jpeg
The pods actually overlay the pillars to push the drivers out as far as possible. Laser scanning and 3D printing in the hands of an expert yields some cool results. IMG_9484.jpeg
Combatvet
I like!
Did some fine tuning on the dash midrange install. Last step will be having the dash mat hemmed where in had to cut it around the pods. This project is 99% done. View attachment 33902
Yep, I'm that way as well:
Hull, GA, USA
Installed a set of cv fab downpipes since one of my stock downpipes cracked. The job was a total pain but I was having a hard time finding someone to do it. I did notice the fada is leaking and luckily I have another month before the warranty is up. Oh and now one of the stock mid pipes is rattling and vibrating at 1500 rpm.
Marietta, GA
2025 Ford Explorer ST 4WD
Installed the Steeda Vertical Link Supports today. They were a tight fit, needed channel locks to press into place. I double-checked the arrows too. Did not take too long.
Installed the AWR brace that I bought from a member . That 3 o’clock diff bolt is a PIA putting back in with the brace.
Midwest
Not necessarily today, more like the last week…new amps and speakers.
Added an Anderson SB50 connector under the hood for easier access to plug in my power supply at audio competitions. Not my first choice of locations but I was limited by the size of the flush mount cover. IMG_9595.jpeg
21 ST
finally got around to putting those mud flaps on, also did the timberline skid plate!
