20x10.5 Wheels
JST15801
DuBois, Pa
Has anyone done a 20x10.5 wheel on their Explorer? Found a nice rim that weighs 24lb but they only make a 20x10.5 32 offset that would fit the Explorer.
That’s literally the perfect wheel setup for these cars. Those wheel specs are pretty much exactly what at least 90% of Explorer owners go with.
Pair it with a 295/45 and enjoy
J
JST15801
DuBois, Pa
Found these and I can choose a single color as well, was thinking gunmetal.
Those look awesome, what wheel is that?
J
JST15801
DuBois, Pa
EKW wheel, found them last night while looking for wheels. They make GTD clone wheels, still have to reach out and make sure the bore is what I need.
Mustangs run the same 70.5-mm hub bore, even if its bigger you can run hub centric rings.
JMDUB117
Victoria, TX
2023 Ford Explorer ST RWD
I'm looking at basically the same tire and wheel setup as the OP but I'm not seeing a lot of +32 offset wheels (at least where I have been looking)
If I had to deviate from the 32 offset, would it be better to go with a 30 or a 35?
Any recommendations on where to shop wheels?
Thanks
Thanks
+30 would be better, but you’re talking a matter of mere MMs so +35 is just fine too.
JMDUB117
Victoria, TX
Thanks. I kinda figured I'd be ok either way but never hurts to check with the pro's.
I'm still trying to figure out where would best to shot for them. I found fitment industries but I got the sense that was the Walmart of shopping wheels lol
Figment Industries has a good selection, so does element wheels and Lethal Performance.
JMDUB117
Victoria, TX
Thanks, I appreciate the help (y)
Been looking at Lethal Performance for other fun items.
J
DuBois, Pa
Thread Starter #13
They emailed that they will machine the bore I need.
