20x10.5 Wheels
DuBois, Pa
Has anyone done a 20x10.5 wheel on their Explorer? Found a nice rim that weighs 24lb but they only make a 20x10.5 32 offset that would fit the Explorer.
That’s literally the perfect wheel setup for these cars. Those wheel specs are pretty much exactly what at least 90% of Explorer owners go with.
J
DuBois, Pa
Found these and I can choose a single color as well, was thinking gunmetal.
J
DuBois, Pa
EKW wheel, found them last night while looking for wheels. They make GTD clone wheels, still have to reach out and make sure the bore is what I need.
Mustangs run the same 70.5-mm hub bore, even if its bigger you can run hub centric rings.
Victoria, TX
2023 Ford Explorer ST RWD
Pair it with a 295/45 and enjoy
I'm looking at basically the same tire and wheel setup as the OP but I'm not seeing a lot of +32 offset wheels (at least where I have been looking)
If I had to deviate from the 32 offset, would it be better to go with a 30 or a 35?
Any recommendations on where to shop wheels?
Thanks
Thanks
+30 would be better, but you’re talking a matter of mere MMs so +35 is just fine too.
Victoria, TX
Thanks. I kinda figured I'd be ok either way but never hurts to check with the pro's.
I'm still trying to figure out where would best to shot for them. I found fitment industries but I got the sense that was the Walmart of shopping wheels lol
Figment Industries has a good selection, so does element wheels and Lethal Performance.
Victoria, TX
Thanks, I appreciate the help (y)
Been looking at Lethal Performance for other fun items.
